Haws Fairlead - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 06-13-2011, 08:21 AM Thread Starter
JKCruise's Avatar
Haws Fairlead
Dose anyone run an aluminum haws fairlead with a cable? I know I've seen some, What are you using to stop the hook/cotter pin from being smashed into the front of the fairlead? Where did you get it?
2011
JKCruise is offline
post #2 of 11 Old 06-13-2011, 08:27 AM
TrailDuty.com
PhilD's Avatar
A steel cable can mess up an aluminum fairlead pretty quickly. If you want to run an hawse with steel cable then a steel one would be a better choice.
PhilD is offline
post #3 of 11 Old 06-13-2011, 08:29 AM
venom's Avatar
phil beat me to it
you use an aluminum hawse with synth line because its soft and wont snag the rope
steel>aluminum so steel line would kill an alum hawse pretty fast.
steel hawse fairleads with steel line work, but are harder on the cable than rollers.
Originally Posted by My Wife
venom is offline
post #4 of 11 Old 06-13-2011, 08:35 AM Thread Starter
JKCruise's Avatar
Yea I'm afraid your right. Do you know the difference in weight between rope & cable? Now I'm trying to sell myself on going to rope because my cable is like new and I hate to waist $...
2011
JKCruise is offline
post #5 of 11 Old 06-13-2011, 08:39 AM
venom's Avatar
A LOT!
most synth rope will actually float
once you use syth line, having to use steel again sucks!
my almost new steel line is wrapped around the inside of a 5 gallon bucket out in the shop
venom is offline
post #6 of 11 Old 06-13-2011, 08:48 AM Thread Starter
JKCruise's Avatar
Originally Posted by venom View Post
A LOT!
Because I haven't research rope what would you recommend? Do they come in 150'? I have a Powerplant if it makes any difference.
2011
JKCruise is offline
post #7 of 11 Old 06-13-2011, 08:50 AM
I bought an aluminum hawse fairlead with a steel insert at Moab 4x4 Outpost at EJS this spring. I don't use the winch much but it looks alot better on the Teraflex bumper than a roller. I'll switch to synthetic when the wire rope gets a bit more use.
Alaska-HWY JK is offline
post #8 of 11 Old 06-13-2011, 08:53 AM
TrailDuty.com
PhilD's Avatar
Yes, but remember that the outer wraps have less pulling power than the inner wraps, so the more line you have on the winch the less pulling power you will have. If you need to do long pulls then you are usually better off getting a 80-100' line on the winch and a separate extension.
PhilD is offline
post #9 of 11 Old 06-13-2011, 09:07 AM
benny's Avatar
I have 100' of 5/16th Amsteel blue on mine and with the hook it weighed in just under 5lbs. I would say the old cable that came off was 20lbs give or take.
Go Play Outside.
benny is offline
post #10 of 11 Old 06-13-2011, 09:07 AM
venom's Avatar
Phil sells masterpull and viking - both are great
http://www.trailduty.com/index.php?c...277353c41242a7
jason and alec have dominion
http://www.eadoffroad.com/winching/w...ope-assemblies
or get it custom in whatever length/options you want from customsplice.com
you won't regret any of them.
only down sides to rope are abrasion resistance - if you plan on dragging it over a lot of rocks, get a nylon wrap, carry a rubber buffer pad to put over the rock (truck mud flaps work well) or stick to steel
and synth doesnt like a lot of UV exposure, so a winch cover or a nylon wrap for the last 15' is a good idea.
I've had a $99 amsteel I got off of ebay on mine for about 3 years now, getting to be about time to replace it.
the great thing about rope - if you DO manage to break it, you can tie it in the field.
I broke mine at the hook - winch remote button went bad and stuck "on" - tied the hook back on with an anchor knot and it's been fine for a year and quite a few pulls.
Obviously not optimal, but it works.
Also synth doesnt recoil when it breaks like steel does- it just drops
venom is offline
post #11 of 11 Old 06-13-2011, 10:39 AM Thread Starter
JKCruise's Avatar
THANKS for all the info! I'll be setting everything up hopefully by the end of the week, new BFH, rigid lights, & rope W/hook.
2011
JKCruise is offline
