Synergy C Gusset Kit - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 06-12-2011, 06:49 PM Thread Starter
RUDY850's Avatar
Can they be welded on with the ball joints in and not messing the ball joints up from the heat.
Also looking at were they go it seems that the upper gusset would hit the lower part of the coil spring. Do they do this with certain springs
RK 3.5 LIFT/RRD SHOCKS/FRONT CONTROL ARMS/DRAG LINK/TRACK BAR/REAR BRAKE HOSES/COOPER 295-75-17 STT JEEPERMAN FRONT BUMPER SUPERWINCH EPI9 JKS LOWER TRACK BAR BRACES/DISCONNECTS CRAGAR WHEELS SOFT 8 SYNERGY UPPER TRACK BAR BRACES RR SKID PLATES BENCHMARK DESIGNS EVAP SKID
RUDY850 is offline
post #2 of 5 Old 06-12-2011, 06:53 PM
StubEXrube's Avatar
You can keep the BJ's in as long as you go back and forth from one side to the other. Also use a wet rag to cool things down.
It's a tight fit with most springs, but there is usually not a clearance issue with springs. I thought I would have to trim my gussets where the spring (almost) contacts the gusset......but there was no need.....just a tight fit.
StubEXrube is offline
post #3 of 5 Old 06-12-2011, 07:01 PM
nc_fjizzle's Avatar
x2 on all above. Just installed my gussets and was worried about the spring as well...all worked out fine.
ΣX
Order from River City Offroad
nc_fjizzle is offline
post #4 of 5 Old 06-12-2011, 10:01 PM Thread Starter
RUDY850's Avatar
Sounds like that should work then
RUDY850 is offline
post #5 of 5 Old 06-13-2011, 07:01 AM
KrawlOff-Road.com's Avatar
Feedback: 37 reviews
Yes just go slow and take your time with the welding and you will be fine! These are a great addition to the axles. Anyone that does any type of offroading should look into these...
-Jason
Phone: 864-437-8029
KrawlOff-Road.com is offline
