Torque - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 06-12-2011, 06:51 AM Thread Starter
Torque
Curious as to how "tight" everyone is setting their after-market adjustable Control Arms with Johnny Joints as well as the front adjustable Track Bar?
Currie recommends setting their Track Bar at 85-ft. lbs. Factory specs call for around 60 (clearly not enough).
Control Arm factory specs call for 130-ft.lbs. At that high torque, concern over cracking the internal ball of the Johnny Joint has been brought up.
Plan on installing my Poly hardware kit today...
Thoughts and thanks.
Brady is offline
post #2 of 11 Old 06-12-2011, 07:11 AM
thaduke2003's Avatar
With my RK arms, I set mine to factory spec. Contact the manufacturer if you're unsure, but factory spec should be good. Just make sure your torque wrench goes up that high- many don't go above 100 ft-lbs.! Mark W.
thaduke2003 is offline
post #3 of 11 Old 06-12-2011, 07:20 AM
jeepersheart's Avatar
I don't know where you are getting 60 for the track bar but the specs I have say 125 for front and rear track bars. That what I did for my RK track bar with no problems.
2008 Detonator 2Dr. 6 Sp.
Jersey
Crew
jeepersheart is offline
post #4 of 11 Old 06-12-2011, 07:27 AM
spedly's Avatar
125ft-lbs on the track bar and the control arms per Poly's instructions
spedly is offline
post #5 of 11 Old 06-12-2011, 07:32 AM Thread Starter
Track Bar specs from my old TJ manual and I agree...way too low. Pretty sure I set my front to 125 as well and plan to do at last 120 with the new hardware kit.
Bought a Snap-On torque wrench last week that goes to 250-ft.lbs. It was pricey but I was sick of busting the cheap (not-so-cheap) wrenches and not at all confident in their accuracy.
Brady is offline
post #6 of 11 Old 06-12-2011, 08:08 AM
i usually just turn it till i fart.
08 yellow jeep jk with river city offroad and home brew special sauce.
mellowyellow is offline
post #7 of 11 Old 06-12-2011, 08:15 AM
will16's Avatar
LMFAO!
will16 is offline
post #8 of 11 Old 06-12-2011, 08:37 AM
The snap-on will be just as inaccurate if you don't get it recalibrated every few months unless it is the beam type.
I have a craftsman 250-ft/lb I use and a smaller craftsman 150-ft/lb. If I break one I take it to Sears and get a replacement.
What sucks is the rear upper control arm bolts I cant get a damn torque wrench on. Just not enough space.
2007 Rescue Green 2-door
A few mods here and there
jgkjeep is offline
post #9 of 11 Old 06-12-2011, 11:59 AM Thread Starter
HA HA HA!
Yeah...just go done installing the Poly hardware, front and back. Brutally hot here in central Virginia. Felt like I was gonna pass out!
Hey jgkjeep - The Craftsman was one of the wrenches I was referring to. Cost me $125...used it about a dozen times...treated it with love...freakin' thing sucked. Tried to take it back to Sears and they wouldn't touch it. Sent it out (through Sears) to get recalibrated and they sent it back to me untouched. I was pissed, to say the least. At least with Snap-On I can give it to a local Snap-On Rep and know it'll get recalibrated correctly.
Brady is offline
post #10 of 11 Old 06-12-2011, 01:00 PM
HA HA HA!
Well that sucks, which snap-on did you get? The prices are actually pretty reasonalbe scanning the snap-on site.
jgkjeep is offline
post #11 of 11 Old 06-12-2011, 03:54 PM Thread Starter
The click-type 50-250-ft.lb. fixed ratchet. It's really nice and well built. Cost me about $300.
Brady is offline
