Bushwacker Flat Fender - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 06-12-2011, 06:25 AM Thread Starter
gerdyj's Avatar
Question Bushwacker Flat Fender
Is anyone having issues with the rubber trim sticking to the body? I've had mine on for about 4 months, and it seems to be getting worse. It's not a huge deal, but for what I paid they shouldn't be doing that. Just curious if anyone else was having the same issue.
gerdyj is offline
post #2 of 17 Old 06-12-2011, 07:18 AM
jkruss's Avatar
Yup, I be honest I am not real happy with them.
Black Jeep
jkruss is offline
post #3 of 17 Old 06-12-2011, 07:24 AM Thread Starter
gerdyj's Avatar
Yeah me either. I really don't see the purpose of the rubber trim, the Xenons don't have it.
gerdyj is offline
post #4 of 17 Old 06-12-2011, 08:35 AM
Are you griping about them sticking to the body (which they are supposed to do) or griping about them pulling away from the body? Mine have been on about three months now and still are stuck ok to the body.
2007 Rescue Green 2-door
A few mods here and there
jgkjeep is offline
post #5 of 17 Old 06-12-2011, 08:55 AM Thread Starter
gerdyj's Avatar
It's actually pulling away from body. It wasn't like that to begin with, just over the last few months I've started noticing it.
gerdyj is offline
post #6 of 17 Old 06-12-2011, 10:44 AM
yuck that sucks
I have some big gaps between the fender and sheetmetal right now. Might have to do with hitting some trees though.
jgkjeep is offline
post #7 of 17 Old 06-12-2011, 11:05 AM Thread Starter
gerdyj's Avatar
Yeah I haven't hit mine on anything. If they weren't so expensive I wouldn't care, but for as much money as I forked over, they should be perfect.
gerdyj is offline
post #8 of 17 Old 06-12-2011, 03:11 PM
bnb2010's Avatar
Mine r doing the same.
Sent from my smoke signals
bnb2010 is offline
post #9 of 17 Old 06-12-2011, 03:19 PM
SONIC's Avatar
Anyone have pictures?
And you didnt spend that much on them lol they are fairly cheap for flatties.
-Doc Holiday
SONIC is offline
post #10 of 17 Old 06-12-2011, 03:26 PM
owtdorz's Avatar
Mine have been on for about 1 1/2 years.
What it sounds like is the fender liner was not trimmed enough or properly and is pushing the fender away from the body.
Did everybody test fit them before applying the tape?
'09 4dr Rubi Detonator Yellow
3.5 Mid arm Rock Krawler
Finally 5.13s
owtdorz is offline
post #11 of 17 Old 06-12-2011, 04:19 PM
toolmanTim's Avatar
All In the prep. When I did mine I made sure every mounting strip was flat and flush and the bolts sitting perfectly in their holes and nice and tight. Then prepped the body with alcohol a couple times over (Fenders too) and laid on the rubber seal. Shoved them on hard and peeled the strip and shoved them on harder and screwed them in. Been mint through the heat and cold ... not a budge.
'10 Surf 2Door Rubicon
'01
<-Vid Flexin' Muscle
6.2 liter Motec Ls swapped 2011 Jku with Rock Jock 60, Dynatrac rcv Pr44, and usual other beef on 37" MTR's.
toolmanTim is offline
post #12 of 17 Old 06-12-2011, 04:25 PM
coilrod's Avatar
Mine pulled away slightly after I side swiped a tree. The branch dented the sheet metal first, then a tap to the rear quarter. I still really like them.
coilrod is offline
post #13 of 17 Old 06-12-2011, 04:27 PM Thread Starter
gerdyj's Avatar
I didn't install mine, my local 4x4 shop did. I don't have a garage, and it was cold outside when I purchased them. I trust that shop completely, they've been in business for over 20 years, and do lots of custom fab work, so I know they can handle a simple flare install.
gerdyj is offline
post #14 of 17 Old 06-12-2011, 04:38 PM Thread Starter
gerdyj's Avatar
Hey, those things are pretty pricey for a piece of plastic.
gerdyj is offline
post #15 of 17 Old 06-12-2011, 06:11 PM
lol I just ripped my fender liners out and threw them away.
I did make sure everything lined up. It was a complete PITA to do but my kid can stand on them no problem when he climbs in and out of the back seat.
If they pull away and get horrible I will probably just pull them off and run without fenders.
jgkjeep is offline
post #16 of 17 Old 06-12-2011, 07:08 PM
Tail Rated's Avatar
Yeah, I too had issues with those rubber strips. Without them, that plastic is rubbing into your paint for sure. Bushwacker sent me a new set @ N/C that I had re-installed. I will have to see if the current owner of the rig is having issues/ success with them.
2016 JKU
Tail Rated is offline
post #17 of 17 Old 06-12-2011, 09:37 PM
charles's Avatar
Mine are still stuck on after a full winter in Colorado. I think, as it was already said, in the prep work. The paint has to be clean. Preparation is always key anytime adhesives are used.
charles is offline
