Superchips - engine stumble? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 06-10-2011, 09:09 PM Thread Starter
Jeep2.0's Avatar
I've had my Flashpaq for a while. Been running the tow tune - good combination of performance & ability to haul. A couple months back I put on 35's & changed the tire size w/ the Flashpaq and also turned off the TPS.
Over the last month or so, I've noticed the engine stumbling now & again. Sometimes at idle, sometimes when starting to accelerate, or when on the highway.
Has anyone seen this? This is the only issue I've had with this & really like it. I'm wondering if I have to remove the tune and update the programmer or something?
2011 5.3L GM LC9 Aluminum LS V8 Conversion w/ Custom Dyno Tune
Aluminum Genright Bumpers Front & Rear - Aluminum Nemesis Rockers
PR44/RCV/Reid Front - Superior Rear - ORF Front / Poly Rear Cage - ORF Tire Carrier
RK 3.5" Springs - Fox 2.0 Adjustable Shocks - JKS Arms & Trackbars - Poly Steering
Jeep2.0 is offline
post #2 of 4 Old 06-11-2011, 01:41 AM
yoda13's Avatar
I haven't had any issues with mine, but you might want to check for an update...they are always updating the software...
2007 Jeep Wrangler X, Auto, Hardtop, White, Superchips Flashpaq, 2" OME HD springs, Rusty's Adj. F/R trac-bars, Bilstein Steering Stabilizer, JKS Quicker Disconnects, JKS Rear Swaybar Extensions, PolyPerformance UCAs f/r, Rusty's LCAs f/r, 33x12.5 BFG KM2s, ProComp 15x8 Rockcrawlers, Smitty winch, Body Armor Front Bumper, FLW SS rear bumper, OEM Rubicon Rock Rails, Skid Row Engine and Tranny Skid, Member UFWD & BRC, †John 3:16†
yoda13 is offline
post #3 of 4 Old 06-11-2011, 02:04 AM
nootherride's Avatar
Sounds a bit like a misfire in a cylinder..try different octane tunes/grades of gas mabe a good fuel cleaner after an oil change..it
I guess what I'm getting at is "stumbling " as your describing I'd usually has to to with air/fuel so check those first..
nootherride is offline
post #4 of 4 Old 06-11-2011, 07:58 AM
D5Fire's Avatar
Send a message via Yahoo to D5Fire
Start simple, make sure all of your spark plug wires are connected good. if you have one sucking air, it will do that.
Fortis cadere, cedere non potest
Poison Spyder BFH w/ trail stinger, custom rear BFH, crusher flares, rocker knockers, evap skid, hood louver. Rock Krawler 2.5 Max Travel, Teraflex rear tire carrier, River Raider cowl snorkel,Warn VR 10,000 lbs winch, sPod, Rigid 50"SR.
D5Fire is offline
