Poly tie rod question? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 06-10-2011, 10:55 AM Thread Starter
I installed the poly tie rod a couple of days ago. At the time I didnt have any locktite so I didnt use it. My jam nut came loose. I retightened and used medium strenght locktite. the problem is that i cannot seem to tighten the tie rod jam nut without the tie rod tilting ever so sliglty downward. Is this a problem? Why is it tilting down? I am using two wrenches, this is passenger side jam nut.
Olean NY Jeeper is offline
post #2 of 2 Old 06-11-2011, 12:31 PM
Jeep2.0's Avatar
It's not a problem - the tie rod ends fix the position. It's all OK.
2011 5.3L GM LC9 Aluminum LS V8 Conversion w/ Custom Dyno Tune
Aluminum Genright Bumpers Front & Rear - Aluminum Nemesis Rockers
PR44/RCV/Reid Front - Superior Rear - ORF Front / Poly Rear Cage - ORF Tire Carrier
RK 3.5" Springs - Fox 2.0 Adjustable Shocks - JKS Arms & Trackbars - Poly Steering
Jeep2.0 is offline
