Bar pin eliminators - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 06-08-2011, 12:04 PM Thread Starter
thaduke2003's Avatar
Bar pin eliminators
Looking at the JKS set, as I'm trying to reduce deflection in the suspension (a fool's errand, I know, but still) to help on-road handling.
Has anyone done these? Any REAL effect? Benefits? Or just another red herring? Thanks! Mark W.
thaduke2003 is offline
post #2 of 9 Old 06-08-2011, 12:19 PM
TrailDuty.com
PhilD's Avatar
I ran BPE's with Fox Emulsion shocks, worked great for mounting the shocks but that's all they did. What do mean by "reduce deflection in the suspension"?
PhilD is offline
post #3 of 9 Old 06-08-2011, 12:31 PM Thread Starter
I mean getting rid of any "squish" in the suspension- deflection is where a bushing's softness allows the travel of a component to deflect, go non-linear, or otherwise divert from the intended path of travel.
I'm replacing bushings with stiffer (higher durometer rating) ones, and so forth. The selling point for me on these is that SUPPOSEDLY they eliminate some deflection from the rear shocks.
I know I need SOME give in the bushings to not turn my JK into a rolling buzzbox (I've owned those in the past- race cars on the street=lost fillings and minds ), but I do want to get rid of some of the OEM suspension compromises- Mark W.
post #4 of 9 Old 06-08-2011, 12:48 PM
TrailDuty.com
PhilD's Avatar
Not sure BPE's will make any difference, but some firmer shocks or springs might. Unless your shocks are sliding around on the pins I don't see you gaining much. I know they move a little on the stock pins, but I'd be surprised if this was noticeable.
PhilD is offline
post #5 of 9 Old 06-08-2011, 12:53 PM Thread Starter
Firmer shocks/springs is rather what I'm trying to avoid- I'm trying to improve handling without touching them.
I have to ask, Phil- why did you run them on your rig? Mark W.
post #6 of 9 Old 06-08-2011, 12:57 PM
TrailDuty.com
PhilD's Avatar
The Fox Emulsion shocks I was running required them.
PhilD is offline
post #7 of 9 Old 06-08-2011, 01:21 PM
scrogg's Avatar
I run a set of PP's rear upper shock mounts. Which aren't necessarily advertised as a bar pin eliminator but do the same thing more-or-less. I can't say that I have noticed any difference in the handling or driveabiltiy of the Jeep, good or bad, since installed.
My sole purpose of getting them was to regain a bit more travel out of my shocks and they have done that for me. Nothing to do with handling or eliminating the bar pin.
I couldn't imagine that a bushing and bar pin eliminators would emilinate as much "squish" as what you may be looking for. I may be completey off, but are you maybe wanting less body roll? Can always look into sway bars.
scrogg is offline
post #8 of 9 Old 06-08-2011, 03:26 PM Thread Starter
Not looking to reduce body roll so much as get truer handling- when bushings deflect, the vehicle is doing something which the driver did not intend- it most often DOES show up as body roll, though.
I am an old race driver, and I appreciate good handling, but what I'd rather have every time is CONSISTENT handling- squishy bushings deflecting make this less possible. There's absolutely no reason the JK can't have solid handling, and I'm getting there, bit by bit Mark W.
post #9 of 9 Old 06-08-2011, 08:40 PM
I installed them after I had to drive home without a shock when I broke a bar pin. Install was very easy and I noticed no difference in my ride, but my suspension isn't very good. These things are really beefy and do add some compression to the bushings. I will be putting them in when I put some new Billstiens in this weekend.
08 Flame Red JK Unlimited, 35" Cooper Discover STT, Mamba M1 Rims, Mopar off road front bumper, CSI 9500lb winch, Warn Rock Crawler rear with tire carrier, OHR Soft Top, Hard Top, Rock Krawler 2.5" Max Travel with Bilstein 5100s, Precision 5.13's and Front and Rear ARB lockers, Riddler Differential Covers, PSC Rocker Knockers, Super Chip.
RedX is offline
