YJ Bumper on the JK - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 06-07-2011, 02:56 PM Thread Starter
Settle's Avatar
YJ Bumper on the JK
I got a smoking deal on a bumper and winch, less than $400; but it was previously mounted on and made for a YJ. So my buddy and I set out last night to get this thing mounted up on the front of the JK. 6 hours, a plasma cutter, grinder, and a welder later.....TADA
Specs are a Smittybilt YJ SRC Stinger Bumper & Smittybilt 8K Winch
On to the pictures
No turning back now
Setting up the plasma table to cut out the frame additions
Cutting them out
Welding the nuts to the bottom of the frame pieces
Frame pieces tacked in to place before BFH to massage the openings
All mounted up and wired
Only thing I didn't show you was the bottom piece of the frame that we had to make. Same thoughts as the top piece, but for only one bolt.
It's held in there with 10 Grade 8 bolts, 8 on the top and 2 on the bottom, so I don't think it's going to go anywhere. I am really happy with the install and I love the new look.
Up next, E-disco flip and skid
2008 Unlimited Rubicon
3" BDS Lift
40" Nitto Mud Grapplers
DIY Beadlocks
Lots of things to come
Settle is offline
post #2 of 15 Old 06-07-2011, 03:02 PM
GRIZZLY47's Avatar
Feedback: 13 reviews
Looks great man! Good job
2010 4-DOOR MOUNTAIN
GRIZZLY47 is offline
post #3 of 15 Old 06-08-2011, 12:49 AM
nc_fjizzle's Avatar
I love it dude. Oh, it's for a YJ? Fuck it, we'll MAKE it fit. Great work.
ΣX
Order from River City Offroad
nc_fjizzle is offline
post #4 of 15 Old 06-08-2011, 12:59 AM
ADDICTION II build begins....
TXROCK's Avatar
great engineering!
U.S. Army
TXROCK is offline
post #5 of 15 Old 06-08-2011, 04:01 AM
vandegrift's Avatar
Looks good and at an awesome price. Can't go wrong there
35" KM2's - Poly Performance Fox Coilover system - TeraFlex Arms - PSC Ram - Rugged Ridge Modular Snorkel - COP 4X4 Nack Attack - Tatton Driveshaft - S-POD - 5.13 and 6 speed.
vandegrift is offline
post #6 of 15 Old 06-08-2011, 08:30 AM Thread Starter
Settle's Avatar
HAHAHA, that was my exact thoughts. I knew it would take some work, but too good of a deal to pass up
Originally Posted by TXROCK View Post
great engineering!
Thanks, it was a little more difficult than I thought, but it was worth it. plus I got to build something in order for it to install on there, and I like doing those kinds of things. Well worth it for me
Yep it was a no brainer for me. My buddy told me about it, I took a few rough measurements and said it'll fit, I'll take it. For the price I couldn't pass it up, plus I got a rear bumper in the mix too that I am going to sell to recoup some of the funds so it should put me right around the $300 in total for the while setup.
3" BDS Lift
DIY Beadlocks
Settle is offline
post #7 of 15 Old 06-08-2011, 08:58 AM
Flip the sway bar and cut that bash bar off. Bfh style
Sent via paper airplane
post #8 of 15 Old 06-08-2011, 09:16 AM
Slow and Low
Co4Lo's Avatar
QUESTION:
Why did you notch the frame to put those nut plates in? You could have simply drilled holes in the frame to line up with the nuts in the plate, slid the plate inside the frame, and bolted through the frame into the nut plates.
That's how I mounted my BFH.
No disrespect, but I would be a little concerned about the integrity of the frame with the amount of force a winch will put on it, or a front end collision.
Just my thoughts, maybe it will hold up just fine.
Co4Lo is offline
post #9 of 15 Old 06-08-2011, 09:49 AM
Originally Posted by Co4Lo View Post
QUESTION:
x2 seemed a little backwards, those long grade8 bolts aren't the most common to come across. But I don't think notching the frame would be my first thought.
post #10 of 15 Old 06-08-2011, 10:14 AM
Echo5Hotel's Avatar
I did this thing but with the SRC front bumper off a YJ to my JK. Ill post my mod pics.
Jeep is gone.
Semper Fi.
Echo5Hotel is offline
post #11 of 15 Old 06-08-2011, 10:26 AM
JKCruise's Avatar
HIJACK
I want to give a buddy my 5 month old TeraFlex bumper off my JK for his YJ, how much work would the JK to YJ swap be?
2011
JKCruise is offline
post #12 of 15 Old 06-08-2011, 01:42 PM Thread Starter
Settle's Avatar
That's the next plan, and then build some kind of skid if necessary to cover the bottom of the disco
QUESTION:
That was my original plan, build a set of nut plates, drill through the frame and attach that way. There were two problems when we went to do that, we had to offset these to the outside of the frame, so when lining up the holes to be drilled there would have been two holes drilled out as normal, but towards the back of the winch plate the holes are a lot close together so where I needed to drill there was going to be one giant hole in the frame and we didn't think that would work. Also we weren't sure how to get those to stay once they were in there, now seeing your picture a plug weld would have done the trick, but honestly neither of us thought about doing that at the time.
So that's where we got the idea, when we decided to recess it back closer to the grill, we notched the frame and welded in the plate. And no disrespect taken, everyone has their own ideas, this is just the one that we came up with. We are by no means master fabricators but I think it will hold up just fine I mean hell, the plates that we cut off from the factory that just about every other bumper that is made for a JK bolts to is just welded onto the front of the frame. Those pieces of metal have as much or more weld surface on them as those plates. If that winch plate or bumper comes off of there then I have other things to worry about b/c I am going to be in much more trouble than something caused by that. I have full confidence in it.
Those grade 8 bolts came right from Home Depot, so not sure how they are hard to come by?? Also, as stated above it wasn't the first idea, but what we came up with as we moved further along with the project.
Would love to see pictures of what someone else did. I searched and searched when I came across the deal from my buddy to see if anyone else had done it. I didn't find anything, but the price was too good to pass up so I jumped on it. I am glad I did, I love the new addition.
man ultimate hijack.....but no biggie......I will say it would not be a direct bolt on, there would be some kind of fabrication needed to swap it over. There is enough of a difference in the frame rails that it wouldn't be a direct fit.
3" BDS Lift
DIY Beadlocks
Settle is offline
post #13 of 15 Old 06-08-2011, 02:31 PM
JKCruise's Avatar
fit.[/QUOTE]
Yea I know...
We took some quick measurements today and it will work but like you said there will be some fabing to be done Thanks
2011
JKCruise is offline
post #14 of 15 Old 06-09-2011, 07:47 AM
Echo5Hotel's Avatar
I got this bumper from my buddy off his 89. Can't beat free.
Jeep is gone.
Semper Fi.
post #15 of 15 Old 06-09-2011, 07:07 PM
curbsjeep's Avatar
Dude with all that equipment why didnt you just make your own bumper
Mango Tango Unlimited Mountain
curbsjeep is offline
