Front Drive Shaft Install - Newb Question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 06-06-2011, 10:14 AM Thread Starter
mofo65's Avatar
Question Front Drive Shaft Install - Newb Question
After tearing my front drive shaft boot, I didn't feel comfortable waiting for the shaft to go so I ordered me a JE Reel shaft (JER-31JK-24F) from PP. My question is am I going to be able to install this without issues or will I need adjustable control arms? I have read where some control arm adjustment is needed. Still have stock arms and I have the PP 3" lift where it's actually 4" up front from stock.
2010 Sahara Unlimited & a 1998 TJ - See my You Tube channel
mofo65 is offline
post #2 of 6 Old 06-06-2011, 10:38 AM
dickyB's Avatar
Send a message via AIM to dickyB Send a message via Skype™ to dickyB
adjustable control arms only change your pinion angle. You should be able to swap driveshafts with no problems. If you get a new vibration after install, then you may need to adjust your pinion.
Originally Posted by Chris Hansen View Post
I like driving my jeep around while wearing a suit....it says I'm formal, but I'm here to party.
dickyB is offline
post #3 of 6 Old 06-06-2011, 10:50 AM Thread Starter
mofo65's Avatar
Thanks Dicky! I feel better hearing that now. Adding new control arms now will not fly with the wife right now so I'm hoping for an easy install.
mofo65 is offline
post #4 of 6 Old 06-06-2011, 11:40 AM
dickyB's Avatar
should be a piece of cake. I broke my front driveshaft my first time out wheeling. Pulled it on the trail, and swapped in another stock one and it's been fine since. I'm running stock control arms too. Make sure you hang on to your old one for a trail spare if the only thing wrong with it is the ripped boot.
dickyB is offline
post #5 of 6 Old 06-06-2011, 11:59 AM Thread Starter
mofo65's Avatar
The DS is still functional and I'm a believer in having spare parts around just in case.
mofo65 is offline
post #6 of 6 Old 06-06-2011, 10:11 PM
pluke the 2's Avatar
ive had a torn boot for about 10k miles and no issues. i don't grease it either. its a myth
Cali Crew
My Youtube Channel:
pluke the 2 is offline
