DW STILL!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 06-04-2011, 12:07 AM Thread Starter
fuknrunit's Avatar
DW STILL!!
Installed FLCA's today, adjustable ones from RC. measured them out at about 23 1/8" eye to eye, and still getting wobble, should i make them a little longer?
or try a new stablizer? i currently have a stock one.
i have an 08 unlimited rubi, with PP 4.5" springs, 35" mud rovers, winch bumper, full armor.
What are your thots?
p.s. im getting it aligned tomorrow. and my trackbar reloc. brackets are coming tomorrow
VOTE # 13 FOR 2011 TTC!!!!!
fuknrunit is offline
post #2 of 19 Old 06-04-2011, 12:19 AM
Cbass122's Avatar
Honestly I would wait to find out what happens at alignment before you start changing things. If you find out your toe is totally out of whack then you probably have your answer.
Still be good to check the normal stuff like BJs and tackbar as well though. Not sure if you did all that already but Planman has the definitive guide for DW issues.
Cbass122 is offline
post #3 of 19 Old 06-04-2011, 07:35 AM
Breaker of nice things
merlin4979's Avatar
The steering stabilizer shouldn't really be the issue, unless it is leaking or broken.
Have you gone through this thread:
https://jkowners.com/forum/showthread.php?t=30723
merlin4979 is offline
post #4 of 19 Old 06-04-2011, 07:35 PM Thread Starter
fuknrunit's Avatar
alignment fixed it!
post #5 of 19 Old 06-06-2011, 09:52 PM Thread Starter
fuknrunit's Avatar
WAIT! it happened again. it only does it if i hit a big bump in the road! what the fuck!!!!
post #6 of 19 Old 06-06-2011, 10:11 PM
Jagrmaister's Avatar
Check the toe first...which should be on your alignment print out. If that's within manners for the 35s...
Oddly enough, when I was running full armor I was getting wobble over large bumps. When I took off the trans skid of my River Raider setup as an unrelated issue occurred, I magically stopped having death wobble over large bumps. There's probably some other issue obviously, but it's been fixed since the trans skid was removed.
2010 Jeep Wrangler 2dr Rubicon with a part from everyone...
Jagrmaister is offline
post #7 of 19 Old 06-06-2011, 10:15 PM
planman's Avatar
Originally Posted by merlin4979 View Post
Have you gone through this thread?
x2
video, pics, and inspection checklist there
planman is offline
post #8 of 19 Old 06-06-2011, 10:27 PM
thaduke2003's Avatar
If your axle is way out of alignment, that COULD be contributing. Another biggie is wheel balance- I stripped a weight off of my driver's front wheel on a rock, and I can tell you it gives me some nice watertight moments (figure it out ) when I hit bumps, especially mid-corner. This is the cause of probably 80%+ of DW that isn't from alignment issues. What were your alignment specs?
Also, at 4.5" of lift, you may need a high-steer kit- I had monster bumpsteer at 3.5" (RK) with adjustable lowers front and rear- the RK steering setup made it go bye bye Mark W.
thaduke2003 is offline
post #9 of 19 Old 06-07-2011, 08:37 AM
Ruskin's Avatar
I'm chasing my own wobble issues. Here's my thread. Following Planman's write-up and fixing/replacing some questionable parts has yielded good results.
https://www.jkowners.com/forum/showth...171#post799171
- Ruskin
Ruskin is offline
post #10 of 19 Old 06-07-2011, 10:14 AM
frankie945's Avatar
IMO. 90 % of the time DW is tire related. Get them balanced.
frankie945 is offline
post #11 of 19 Old 06-07-2011, 01:18 PM
planman's Avatar
That isn't DW. DW is from loose or damaged components.
Loose trackbar bolts or damaged ball joints can't be fixed with a tire balance--or a steering stabilizer.
Sent from my DROIDX using Tapatalk
planman is offline
post #12 of 19 Old 06-07-2011, 01:33 PM
frankie945's Avatar
So I guess when the steering wheel shakes so bad you have to almost come to a stop for it to get back to normal isn't DW. I ve put lifts on 3 jku's now. And all had DW. And they all turned out to be the tires. My old H2 would get DW so bad after hitting a pot hole. I would have to completely stop. It turned out to be tires as well. The were wore on one side. Which was the cause of it. New shoes it was like new.
I know u think u know everything about DW. But its not always loose or damage parts. In my experience the tires seem to be the cause.
Sent from a Android on Tapatalk..
post #13 of 19 Old 06-07-2011, 01:45 PM
It's not REALLY death wobble when your tires are out of balance and you hit a bump- it's bumpsteer, which is a temporary form of DW- not QUITE the same, but to most people, they'd think it was and call it, death wobble Also, it's commonly mis-diagnosed. It'll fix, as Frankie and I have mentioned, a great many cases of "death wobble" to re-balance the wheels/tires- Mark W.
post #14 of 19 Old 06-07-2011, 02:11 PM
planman's Avatar
I certainly don't know everything, but this is not from bad tires:
YouTube - ‪Death Wobble‬‏[/SIZE]
YouTube - ‪JK Death wobble.wmv‬‏
Bad or out of balanced tires definitely do cause problems. The vibrations/shimmies can expose the true sources of DW. So, they are a trigger, but not a source.
planman is offline
post #15 of 19 Old 06-08-2011, 09:03 PM Thread Starter
fuknrunit's Avatar
could high tire pressure be a potential cause?
post #16 of 19 Old 06-08-2011, 10:09 PM
Doubtful- unless you had E-ranges are were running 60 PSI, I doubt it- Mark W.
post #17 of 19 Old 06-08-2011, 10:10 PM
planman's Avatar
It could be a trigger, but typically not a source.
planman is offline
post #18 of 19 Old 06-09-2011, 02:52 PM
jrylb73's Avatar
Ok here is my 2 cents. We had the same problem. You need to check the track bar bolt hole on the frame side and make sure it is not out of round. Ours must of came loose and caused it to become out of round, so we took it and had a grade 8 washer welded over the bolt hole to make it round again. That fixed our DW. Like I said that is just my 2 cents
jrylb73 is offline
post #19 of 19 Old 06-09-2011, 06:40 PM Thread Starter
fuknrunit's Avatar
thanks for the feedback, i know this topic is a dead horse that gets the shit kicked outta it all the time.
btw, hittin the rubicon fathers day weekend. anyone goin up?
