New seats installed harness ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 06-03-2011, 08:07 AM Thread Starter
jeepnick's Avatar
Got my new seats installed
Mastercraft baja rs
Wow the quality is amazing, way more comfortable then my corbeau cr1's
Goal is to but the corbeaus in the rear, working on modifying the mastercraft rear bracket so they will fit
Anyway My question is with the rock hard harness bar how are you guys securing the shoulder straps? To each other?
jeepnick is offline
post #2 of 15 Old 06-03-2011, 08:29 AM
Mitchw123456's Avatar
I bought the master raft harnesses that were designed to be bolted in (can't tell from the pics what yours are). All I did was drill two 1/2" (if I remember correctly) holes and bolted them in and cut off the little loop holder bracket thingamajig..
Mitchw123456 is offline
post #3 of 15 Old 06-03-2011, 08:45 AM
2k2wranglerx's Avatar
In case anyone cares those are master craft seats on corbeau brackets... So if you decide to upgrade to mc seats you just have to drill 2 holes and they'll work!
The corbeau seats on mc brackets however.... That takes a little more... "engineering". Lol
2k2wranglerx is offline
post #4 of 15 Old 06-03-2011, 09:05 AM
thaduke2003's Avatar
I attached mine to the seat bracket bolts. Not ideal, but the angles were within 2-4 degrees of ideal, as according to some racing sheets I have Mark W.
thaduke2003 is offline
post #5 of 15 Old 06-03-2011, 09:06 AM
Ipe
Ipe's Avatar
I've got a Rock Hard harness bar, Crow Harnesses, and unfortunately... the oem seats still. I want the ones you got. Oh well, one of these days.
Anyway, I ordered my Crow Harnesses with the wrap around mounting option. Similar to what you see here:
Different harnesses have different mounting options. If you're not sure about how to mount them you might want to contact whomever sold them to you to verify what you have and what is the correct mounting method. Installing them wrong could be a bad thing.
Ipe is offline
post #6 of 15 Old 06-03-2011, 09:24 AM
http://www.summitracing.com/parts/GFR-109L/
Bryan can get em too. The master craft pn is
mcs11351
post #7 of 15 Old 06-03-2011, 09:25 AM Thread Starter
jeepnick's Avatar
I know what I have
Mastercraft harness's
They do have the clip end just like the lap belt, I can drill a hole with an eye bolt
Just wondering what everyone else is doing
jeepnick is offline
post #8 of 15 Old 06-03-2011, 09:57 AM
BenFoo's Avatar
Nick,
Which harnesses did you get?
There are some designed to wrap around the bar and some that need to be bolted into the bar. The easier of the two is the wrap around, the bolt in requires some modification.
example:
BenFoo is offline
post #9 of 15 Old 06-03-2011, 09:58 AM
BenFoo's Avatar
P4x4 writeup on harnesses is good: http://www.pirate4x4.com/tech/billavista/Harnesses/
and Harness Install -- http://www.pirate4x4.com/tech/billav...rness_install/
BenFoo is offline
post #10 of 15 Old 06-03-2011, 10:13 AM Thread Starter
jeepnick's Avatar
Good read
Mine are mastercraft with quick release ends look like they could be wrapped around as well
What's anyone with harness's and Rock hard harness bars doing?
jeepnick is offline
post #11 of 15 Old 06-03-2011, 11:06 PM
That looks great, nice install. Post how well they hold up over time after you've had them a while..
post #12 of 15 Old 06-03-2011, 11:32 PM
JKrazed's Avatar
Feedback: 13 reviews
My 3" Crows came with both, the wrap-around, as well as the bolt in tabs.
I chose to use the wrap-around style.
PROUD to be an
JKrazed is offline
post #13 of 15 Old 06-04-2011, 07:51 AM
The Joker's Avatar
I have these. I really don't need the "Submarine" belt.
Great belt for the price, plus the aircraft bluckle is much easier to deal with. http://www.summitracing.com/parts/RCI-9450D/
The Joker is offline
post #14 of 15 Old 06-04-2011, 08:08 AM
I almost bought those but I do wish I wouldve sometimes. I catch hell with sand in my latches making them impossible to operate without keeping a bottle of water around.
post #15 of 15 Old 06-04-2011, 05:42 PM
I did the wrap around for the harness bar and bolt in for the lap belt. Just took some uni strut and bolted them in to the seat mounting bolts.
