15" JEGS Baja-8 Steel Wheels and 35's - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 06-01-2011, 08:45 PM Thread Starter
THIN ICE's Avatar
I had these mounted last week I started to buy the soft-8's for 49 but found these on Jegs for 42 they have 3.75" bs not 4" bs like the soft-8. The big surprise was that I didn't have to grind the brake calipers they fit with out any modifications. The local Goodyear got me the MTR K in one day.
THIN ICE is offline
post #2 of 16 Old 06-01-2011, 08:49 PM
looks great!
post #3 of 16 Old 06-01-2011, 08:51 PM
Awesome combo. But I'm a little biased
BBirish is offline
post #4 of 16 Old 06-01-2011, 09:25 PM
mbjeepxj's Avatar
got a pic of how far they stick out from the fenders?
☀lllllll☀ 2014 Cherokee Trailhawk
☀lllllll☀ 2009 Unlimited X
☀lllllll☀ 1985 CJ-7
mbjeepxj is offline
post #5 of 16 Old 06-01-2011, 09:26 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
Man that's a killer deal on those wheels! I don't understand how some of them are 3 times that much for the same wheel. LOL!
You'll really like that setup, I ran it on my JK for about a year without any issues. Those 15s make the 35s look huge, don't they?
Marcus
RiverCityOffroad is offline
post #6 of 16 Old 06-01-2011, 09:33 PM
MJC
MJC's Avatar
Do you rub at all at full flex?
'13 JK Rubi...stock for now.
Retired: 2010 JK Rubi...4" lift on 35x15 km2
MJC is offline
post #7 of 16 Old 06-01-2011, 10:38 PM
JKO Dickhead
Asmmns's Avatar
ya think ?
__________________
CURE SMA !
Asmmns is offline
post #8 of 16 Old 06-01-2011, 11:10 PM
You'd be surprised! I bet he doesn't get much rub when he flexes it out.
Below is my JK with a 2.5" budget boost, 15s & MTRs but 4" of BS. It would only rub in the exact center of the fender flare on the rivet that holds the inner fender in and it was only when the tire was turned just right.
I only took it out like that once and then I hacked them all to bits.
post #9 of 16 Old 06-02-2011, 04:59 AM Thread Starter
THIN ICE's Avatar
I have not had a chance to flex it out yet but I'm sure the front fender would rub and maybe the Rubi rock rail.
The cost was one reason I went with this set up and I really like the look.
4 Wheels> $180 Shipped - 4 MTR K > $1100 out the door,Mounted,Valve stems,Balanced,Lifetime Balance and Rotate
THIN ICE is offline
post #10 of 16 Old 06-02-2011, 05:50 AM
mbjeepxj's Avatar
sweet.. that doesn't look like it sticks out any further than my wife's Unlimited with stock wheels, 1.5" spidertrax, an 35" MTR/K's
thanks... thinking about this setup for my 2-door Rubi...
☀lllllll☀ 1985 CJ-7
mbjeepxj is offline
post #11 of 16 Old 06-02-2011, 06:11 AM
bubba2u's Avatar
if you didnt fit every wheel on the front to see if it clears the caliper you may have an issue on the trail if you get a flat and have to. imho
bubba2u is offline
post #12 of 16 Old 06-02-2011, 07:13 AM
KrawlOff-Road.com's Avatar
Feedback: 37 reviews
Looking good buddy! Now we just need to take it out on the trails and get it dirty!! Let me know when your ready...
-Jason
Phone: 864-437-8029
KrawlOff-Road.com is offline
post #13 of 16 Old 06-02-2011, 09:22 AM
JKO Dickhead
Asmmns's Avatar
with my old setup like marcus... 2.5 BB and 35's GY mtr's on 15X10's my front wasnt a problem... it was the rear fenders..trust me....
your right the front rubs far enough where it can flex a little.... I flexed the rear once in this state... about ten of the plastic retainer clips flew off in multiple directions and multiple peices and then the fender was holding on by a few of teh top clips and rattled like mofo...
immediately cut the fenders and got me some new clips.....still rubbed on the rear pinch seams with my 2.5 RK stock mod... cut those on both sides of the tires and I was ok at full flex... if you want to take advantage of teh flex you gotta do some trimming....
no the best pic, but if you compare to stock you will see how much was actually cut...this should give u an idea
__________________
CURE SMA !
Asmmns is offline
post #14 of 16 Old 06-02-2011, 12:13 PM
^ looks close to my setup. Here is mine fully stuffed upper control arms only for the rears.
15x8 3.75bs 35x12.5 mtrk. The only thing I trimed was the rock slider. This is on the stock rear bump stops. PP springs and some cheepo shocks at the time.
Commando Green 2d, rear stretch on 37's
RockLover is offline
post #15 of 16 Old 06-02-2011, 07:42 PM Thread Starter
THIN ICE's Avatar
-Jason
Soon I hope
THIN ICE is offline
post #16 of 16 Old 06-02-2011, 10:42 PM
JKO Dickhead
Asmmns's Avatar
nice pic....that is stuffed !!! shows you how much more romm is available without the stock fender hanging down !! nice
__________________
CURE SMA !
Asmmns is offline
