rock krawler joints ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 06-01-2011, 08:23 PM Thread Starter
OIIIIIIIO's Avatar
when using loctite on krawler joints do you just put loctite on jam nut or all of the thread inside the control arm
2010 2 door rubicon
RK 5.5 MID ARM
OIIIIIIIO is offline
post #2 of 5 Old 06-01-2011, 08:47 PM
JK Timmay's Avatar
I put it on the threads of the joint itself, then tightened down the lock nut.
JK Timmay is offline
post #3 of 5 Old 06-01-2011, 09:26 PM
spookylynx's Avatar
even though they suggest the red stuff, be careful and not use too much, that stuff is strong just use a little or use the blue. Also, I just put one of their lift on, dont put it on right away, make sure everything is lined up right and all angles are right. Their measurements are really good but may still need some tweeking then when everything is perfect go back and do it.
spookylynx is offline
post #4 of 5 Old 06-02-2011, 08:14 AM
Just on the interface for the jam nut! If you put it inside the arm it will make it hell to adjust in the future!
RK
post #5 of 5 Old 06-02-2011, 03:57 PM Thread Starter
OIIIIIIIO's Avatar
THANKS RK THAT WAS THE ANSWER I WAS LOOKING FOR I WANT TO BE ABLE TO ADJUST IT LATER
2010 2 door rubicon
RK 5.5 MID ARM
