Rock Krawler Ultimate steering upgrade- anybody running it? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 05-25-2011, 08:38 AM Thread Starter
VADERJKU's Avatar
I tried searching and came up empty handed. Opinions, tips? Thanks!!!
VADERJKU is offline
post #2 of 17 Old 05-25-2011, 08:57 AM
block's Avatar
i have it highly recommend ... makes a big difference, i have everything dialed in, i dont even need a steering stabilizer with 37's and beadlocks
block is offline
post #3 of 17 Old 05-25-2011, 09:01 AM Thread Starter
VADERJKU's Avatar
SWEET!!! Thanks for the info (and great pic)!!! What lift are you running? Is that their aluminum tie-rod, how do you like it?
VADERJKU is offline
post #4 of 17 Old 05-25-2011, 09:11 AM
block's Avatar
thanks I'm running their new pro aluminum kit.5.5".. with coilovers and their remote res shocks.. i love everything about it.. it is awesome ! yea it is their aluminum tie-rod .. very beefy and strong.. plus it looks cool
block is offline
post #5 of 17 Old 05-25-2011, 09:20 AM Thread Starter
VADERJKU's Avatar
That it does! Sounds like you have a sweet setup overall!!!
I am debating the steering upgrade since (like any other high steer kits that I have seen) you have to run longer bumpstops to keep the steering out of contact with the frame (RK said 3" minimum bumpstop extensions). As I am going to be running only a 3.5" lift (RK's X factor midarm) I am wondering if I will have enough uptravel to be happy?
VADERJKU is offline
post #6 of 17 Old 05-25-2011, 10:13 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
I have a friend/customer running a 2.5" RK Stock Mod on his Unlimited with the Poly Performance steering correction kit. He started with 3" of bumpstop in the front and took an inch out.
I am waiting on him to send me the picture of his Jeep on a ramp so you can see the up-travel he still has.
Marcus
RiverCityOffroad is offline
post #7 of 17 Old 05-25-2011, 10:33 AM Thread Starter
VADERJKU's Avatar
Marcus
AWESOME! Thank you sir!
I am just rather paranoid about it since the only other Jeep I have owned was a ZJ on a 4.5" lift that for some reason (I can't recall what, some clearance issue, I think it was the stock steering hitting the swaybar mounts our something, it's been several years ago now) had to have 4.5" extended bumpstops (thus stock uptravel) and bottomed out really harshly a LOT whilst I was wheeling it. I went with a Teraflex steering setup on it to try to alleviate the clearance issues and ended up with TERRIBLE bumpsteer (which is exactly what that kit said it would get rid of, LOL!) plus, that kit had some sketchy weirdness to it (IMO) such as swaybar brackets that you weld to the middle of the inner C's (looked quite odd and didn't inspire confidence in its strength).
VADERJKU is offline
post #8 of 17 Old 05-25-2011, 12:19 PM
Abadjeeper's Avatar
LevillinBrad runs it on his Jeep w/ the 3.5 X factor and it hits the frame during articulation. We are right up the road from you if you ever want to check it out.
Jeremey
Abadjeeper is offline
post #9 of 17 Old 05-25-2011, 12:45 PM Thread Starter
VADERJKU's Avatar
Jeremey
Did he extend the bumpstops, or no? If so, by how much? Is he happy with the amount of uptravel it allows?
I'd definitely like to check it out, thanks bro!!!
VADERJKU is offline
post #10 of 17 Old 05-25-2011, 12:47 PM
You need to extend your bump stops a minimum of 3" with that setup or the bracket will hit the frame. This should be the case of all high steer setups..
RK
post #11 of 17 Old 05-25-2011, 01:14 PM Thread Starter
VADERJKU's Avatar
RK
That's what I had figured! Thanks! I was just wondering if he had extended them 3" and was still hitting or what was going on?
VADERJKU is offline
post #12 of 17 Old 05-25-2011, 01:38 PM
Here is Jeff's rig. It is on 35" MTRs & 2.5" Stock Mod. 3" bump stops pictured here:
post #13 of 17 Old 05-25-2011, 01:45 PM Thread Starter
VADERJKU's Avatar
AWESOME!!! Thanks for the pic Marcus!!!
VADERJKU is offline
post #14 of 17 Old 05-25-2011, 09:17 PM
fourplyn's Avatar
I have the 3.5" kit.. full flip in front..all pro alum.. I wouldn't want anything else.
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #15 of 17 Old 05-25-2011, 10:22 PM Thread Starter
VADERJKU's Avatar
Cool, thanks bro! By the way, that's quite a nice build you've got going there!!! Great work! I love the attention to detail you have put in!
VADERJKU is offline
post #16 of 17 Old 05-27-2011, 09:04 PM
SofaKing's Avatar
Uh, that's not Austin.....
2009 Silver Unlimited Rubicon -- Not really stock, anymore.
SofaKing is offline
post #17 of 17 Old 05-30-2011, 01:14 AM
Jeff lives south of Austin, near me. The picture was taken at Tribe4x4 in Fort Worth after they installed his gears.
I didn't claim that I took the picture...not sure what you were hinting at.
