Engine Light v6 flash out? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 05-11-2011, 04:46 PM Thread Starter
Hi guys long time, was at Pep Boys today for a tire rotation and oil change they checked my engine light which I kept forgetting to look in to the book to see and they said it was a cylinder was cutting out I forgot the terms he used, but the 6th one was back firing I think it was. Any ideas?? Thanks for your help
OME HD LONG TRAVEL LIFT F&R TRACK BARS CURRIE UPPER CONTROL ARMS JKS DISCONNECTS
marcoseddi is offline
post #2 of 7 Old 05-11-2011, 06:11 PM
2k2wranglerx's Avatar
Missfire code?
2k2wranglerx is offline
post #3 of 7 Old 05-11-2011, 07:12 PM
jss
jss's Avatar
Truck Hemi in a JK
Number 6 cylinder is misfiring, ether a bad wire or a bad plug.
jss is offline
post #4 of 7 Old 05-11-2011, 08:00 PM Thread Starter
jk
Thanks guys is it an easy fix? Can I do this or should I have someone do it and if so approx what would it cost to do or should cost I should say?
post #5 of 7 Old 05-11-2011, 11:34 PM
jss
jss's Avatar
Truck Hemi in a JK
You could swap the wire with another one and see if the miss moves to the other cly.
jss is offline
post #6 of 7 Old 05-12-2011, 04:46 AM Thread Starter
K
Don't even know where this wire would be or where to start..
post #7 of 7 Old 05-12-2011, 06:28 AM
BeerMonkeY's Avatar
sounds like you should take it somewhere or ask a fellow jeeper friend for some help with it. Its not hard to do but if you have no idea what to do it may seem difficult
'92 YJ
'13 WK2
BeerMonkeY is offline
