Fuel Cell - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 05-11-2011, 02:42 PM Thread Starter
Fuel Cell
I'm putting a fuel cell in the back of my jeep, what is everyone using for the pump and sending unit.
08 rubicon atlas 2 speed danna 60 rear custom tube work psc steering tons of other stuff oh and 42's
Check out my Rock Solid Fabs JKuggy build
RokinRubi is offline
post #2 of 8 Old 05-11-2011, 05:22 PM
guinness's Avatar
Really depends on what you are buying.
Genright makes one that is compatible with stock and carolina truggies also is making one for the jk.
After that your guess is as good as mine. Talk directly to the site vendors and other mfgs to get a better idea of what is avail.
Rest In Peace Guinness. You will never be forgotten. My brother and my best friend
guinness is offline
post #3 of 8 Old 05-11-2011, 11:37 PM
jss
jss's Avatar
Truck Hemi in a JK
We are using a TJ tank in the rear of are JK 2 door
jss is offline
post #4 of 8 Old 05-12-2011, 05:30 AM
Do you have any pics of this. Im wanting to do the same thing, dosent seem like it would be too hard. What pump and sending unit are you using? Do you still have to use the EVAP canister?
Sorry for the thread jack.
HOT_DAMN is offline
post #5 of 8 Old 05-12-2011, 07:23 AM
jss
jss's Avatar
Truck Hemi in a JK
We are making a skid plate to make it easy but if you what to do it on the cheap.
The TJ gas tanks from 1997-2000 will work but you will need to do a little work with the evap and you will need to use a 2005-2006 fuel pump, for the right fuel PSI.
The TJ gas tank from 2001-2004 will also work, the evap system is even closer to the JK but some mods will have to be done, you will also need to use the 2005-2006 fuel pump.
The best tank to use is the 2005-2006 all of the evap stuff is the same and the fuel pump has the right PSI.
All you need to do is modify the front mounting brackets and relocate the rear body mounts and it will work.
You could put the tank in for the price of a good used fuel tank. ($100.00)
We are going to have more of this coming up, with pics and info.
jss is offline
post #6 of 8 Old 05-12-2011, 03:51 PM Thread Starter
well dang guess guess what my buddy has everything I need laying around and we are gonna try to do this swap and see how it goes
post #7 of 8 Old 05-15-2011, 05:28 PM
gfe jeep's Avatar
wow
great thread!
gfe jeep is offline
post #8 of 8 Old 05-16-2011, 08:44 AM
Matt Wright's Avatar
Yea, Dave should have all that layin' around lol
AKA: "American" on PBB
Matt Wright is offline
