Tire Pressure on 37 inch mtr's - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 05-08-2011, 07:44 PM Thread Starter
I know that this might have been said someone but i searched.... Please post if you know.... I am running 35psi per Tire Kingdom.... i was at almost 50 psi.... what should i be running? please help!
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42 MTR's
17" Spyderlock Beadlocks
post #2 of 13 Old 05-08-2011, 08:31 PM
Chalk test is the best way to get your tire pressure for your Jeep tire/wheel combo. 35psi is a good start point.
4x4x4 is offline
post #3 of 13 Old 05-08-2011, 09:39 PM
I am running 30 psi in mine
08 Detonator Yellow Rubicon-RE Arms-37" Mt/R's with Kevlar-Riddler Diff Cover-LoD stubby with Stinger-LoD stubby tire carrier-Warn M8000 Winch-Rigid D2's-20" Rigid Light Bar-SPOD-PS Rocker Knockers-PS Body Armor-5.13s-hydro assist-RCV shafts-IPF-Corbeau LG1 seats-12" King coilovers-AEV Hood-AEV Snorkel-5.7L VVT Hemi-AEV hemi Install Kit-4.5" AEV Springs-ProRock 44-AlloyUSA Rear shafts-Spyntech Hubs-Raceline Monters-
Fishyguy is offline
post #4 of 13 Old 05-08-2011, 09:45 PM
TxVet82's Avatar
35 psi in mine. Non kevlar if that matters.
Sent via Morse Code using my iJeep
2007 JEEP Green RUBICON
"If you can read this thank your Teachers, If it is in English thank your Soldiers."
TxVet82 is offline
post #5 of 13 Old 05-08-2011, 10:01 PM
StubEXrube's Avatar
37" MTR's. Running about 32 lbs front/ rear.
StubEXrube is offline
post #6 of 13 Old 05-08-2011, 10:48 PM
tehiv's Avatar
x2
37" MTRs - 31 psi on all 4
tehiv
'14 Copperhead JKUR
'14 White WK2 Overland
formerly: 98 TJ | 97 XJ | 05 TJ | 01 WJ | 07 JKU
tehiv is offline
post #7 of 13 Old 05-08-2011, 11:51 PM
Moose512's Avatar
I run my 37" MTR Kevlars at 35psi. If I go any lower it throws the stock TPMS light. If it wasn't for the light I would probably run them at 28-30psi for city driving.
I ran them at Moab at 15psi for the entire week and other then the light being on they performed well on and off the trail. Sidewall is very stiff on the MTR Kevlar.
Moose512 is offline
post #8 of 13 Old 05-08-2011, 11:51 PM
I'm running 37" KM2's at 35psi for over a year and they seem to be holding up fine.
post #9 of 13 Old 05-09-2011, 10:38 AM
TrailDuty.com
PhilD's Avatar
X2 I just mounted some 37" MTR/K this weekend and running 28 psi.
PhilD is offline
post #10 of 13 Old 05-09-2011, 04:06 PM Thread Starter
I went to the Jeepers den today to fin out why my tire was so low.... There is a gash in my tire.... I don't think I could've hit anything and it is a clean cut! Just what I need!
Sent from my iPhone using Tapatalk!
-Marc
Coming up:
EVO Long Arm
40/42 MTR's
post #11 of 13 Old 05-09-2011, 04:16 PM
ALASHA's Avatar
Sounds like you might have a hater lurking around
ALASHA is offline
post #12 of 13 Old 05-09-2011, 04:23 PM Thread Starter
Yeah I don't like it! And it is a clean cut too! I am going tonight to get the tire patched so I can hold out for a few months until the tire carrier comes!
-Marc
Coming up:
EVO Long Arm
40/42 MTR's
post #13 of 13 Old 05-09-2011, 04:31 PM
Mr.RonGilbert's Avatar
Did the chalk test on mine and 30psi was just right. It seems like the best psi for ride as well.
Mr.RonGilbert is offline
