Fox remote res. adjustable shocks?? Opinions please... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 05-08-2011, 06:39 PM Thread Starter
If you have tried the adjustable Fox remote res. shocks I would like to hear from you.
What did you think?
Did you stay with them?
How would you describe the type of use/abuse you subject them to?
If you were not happy with this shock, what other shock (brand and model) did you prefer and for what reason?
Thanks...
dye4it is offline
post #2 of 12 Old 05-08-2011, 06:53 PM
Mr.RonGilbert's Avatar
What did you think?
Like'em
Yes
Rocks and mud when I can't avoid it.
What other shock (brand and model) did you prefer and for what reason?
Weird question.... but I chose the Fox's because they are what I preferred - I had the pro comp cheap-o's before. If I didn't get the Fox setup I would have gone with the new Rock Krawlers, Race Runner or King.
Thanks...
No sweat
In Red
Mr.RonGilbert is offline
post #3 of 12 Old 05-08-2011, 06:57 PM
Diesel's Avatar
I have the fox resv shocks. They are not the adjustable ones, but do have resv. I change the nitrogen from 75-250 depending on what I'm doing. Those with the TF speed bumps are the best,and cheapest, I can find with out doing evolution double throw down.
Diesel is offline
post #4 of 12 Old 05-08-2011, 07:02 PM Thread Starter
@MrRonGibert I can see how the one question reads weird. I will edit... I meant... "If you were not happy with them what did you prefer and why?"
dye4it is offline
post #5 of 12 Old 05-08-2011, 07:05 PM
No harm done
And someone besides me may be able to *feel* the difference in the adjustments - mine are basically stiff on any setting. They are currently on the "softest" setting and are still a bit stiff IMO.
Do some searching as well, there have been many discussions on shocks - including the FOX adj types - over the years.
post #6 of 12 Old 05-08-2011, 07:24 PM Thread Starter
Thank you for the replies...
I have done some searching and have found many very long threads on unrelated or under-focused topics, and some threads with information useful to my needs. However, it is difficult to apply peoples subjective opinions to my own situation without knowing something about their frame of reference. I started a new thread hoping to learn a little about expectations and types of usage along with impressions of how well they worked.
For instance:
If they are "harsh", how are you using it and compared to what?
If they are "better than stock", what were you looking for that "stock" didn't satisfy?
If they were "disappointing" or "awesome", I want to know why.
dye4it is offline
post #7 of 12 Old 05-09-2011, 12:03 AM
I've had them on the back of my long arm coilover build for over 2 years. Just outstanding performance, I'm still impressed.
What did you think? Love them.
Did you stay with them? The work great and are rebuildable, why change.
How would you describe the type of use/abuse you subject them to? Lots of wheeling with no bumpstops - so I over compress them and still no seal leaks!
If you were not happy with this shock, what other shock (brand and model) did you prefer and for what reason? N/A
post #8 of 12 Old 05-09-2011, 08:19 AM
TrailDuty.com
PhilD's Avatar
I had Fox CD adjustables and generally liked them. They got the location of the front reservoirs wrong initially which resulted in them getting messed up, but they fixed pretty quickly. I found the adjustments to be quite noticeable, but I've heard others say there isn't much difference.
I didn't stay with them as I went to coilovers.
PhilD is offline
post #9 of 12 Old 05-09-2011, 08:29 AM
Fox makes great products. Look into getting a well tuned set of Remote Ressy units instead of the adjustable ones. All companies are doing with the adjusters is controlling the "bleed" of fluid in and out of the remote reservoir. They are not dynamically changing the valving. This method of adjustment actually heats up the fluid and you are much better off without it. You will also save money by going with the standard RR shocks from them. Great products and a great company.
RK
post #10 of 12 Old 05-09-2011, 09:40 AM
I agree with RK on this one. I am far from an expert so take it FWIW. I still think mine are a little stiff, even on the softest setting, and have emailed Fox about making them softer. I can send them in to be tweaked but its a bit of a PITA to remove all four and have the vehicle down while waiting to get it them back. If I had it to do over I would buy a set of RRs that were valved to fit what I wanted. I am more of a set it and forget it kinda dude. I am sure there are some folks make adjustments and hopefully they will provide some feedback. I am on the road and on the rocks.... that's about it.
post #11 of 12 Old 05-09-2011, 11:10 AM
jsmoriss's Avatar
I've had the fox for a few years now. I run 'em at 3 on the road, and 7 on the trails. I find the different adjustments make a big difference. They can be a little harsh in the winter, but I've been a bit lazy and leave 'em at 3 even in the winter. I forget the exact bumpstop height I'm using, but it's less than 3". I took the coils out and cycled the suspension to size the smallest bumpstops I could (getting max articulation out of the shocks). I'm not using limiting straps. After 2 winters (I think) you can see the salt starting to get at the aluminum. I've had to use spray lube on two of the adjustment knobs. The fox are rebuildable, but of course while you rebuild them (or have someone do it), you'll need to put on a second set. ;-) The Kings weren't available yet when I got the Fox, or I might have gone for those.
js.
jsmoriss is offline
post #12 of 12 Old 05-09-2011, 09:24 PM Thread Starter
Thank you all for the responses. Your input is much appreciated. I placed an order for the adjustable version of the remote res. shocks. I will be using them with a Stage 3 Poly Performance 3" lift. I think i will be the type that will be changing the "tune" for the task at hand.
dye4it is offline
