Which is better? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 05-07-2011, 09:10 AM Thread Starter
Which is better?
I am looking to run 35 12.50 wheels i want to run wide rims 9 or 10 " are there any negatives to running such a wide rim?
gregkelley is offline
post #2 of 6 Old 05-07-2011, 09:12 AM
dickyB's Avatar
Send a message via AIM to dickyB Send a message via Skype™ to dickyB
If you wheel it, those wider rims are more likely to get torn up at the lip.
Originally Posted by Chris Hansen View Post
I like driving my jeep around while wearing a suit....it says I'm formal, but I'm here to party.
dickyB is offline
post #3 of 6 Old 05-07-2011, 09:16 AM Thread Starter
What width is good to run i do go wheeling on the weekends n dont want my rims screwed up but i dont want my tires to look pulled in at the rims either. i dont know if this matters but i will prob be running rock rings. Thanks for all the help
post #4 of 6 Old 05-07-2011, 10:23 PM
desert dog's Avatar
Especially in that tire size, the wider rims seem to loose beads more often while aired down. And like stated, they get shredded in the rocks. an 8" wheel is perfect for those tires.
desert dog is offline
post #5 of 6 Old 05-08-2011, 07:16 AM
dickyB's Avatar
I run a 15 x 8 wheel on that size tire. It works well for me. I typically air down to 10-12psi and have never lost a bead while wheeling. Knock on wood
dickyB is offline
post #6 of 6 Old 05-08-2011, 07:30 AM
JKO Dickhead
Asmmns's Avatar
I run a 15x 10 on 35" Kevlar MTRS..
like the look better, however the above posts as far as performance/problems are probably right on
__________________
CURE SMA !
Asmmns is offline
