detroit locker install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 05-06-2011, 04:27 PM Thread Starter
kevo's Avatar
just bought a detroit noslip for the rear 44,do i need to purchase a carrier bearing kit?
kevo is offline
post #2 of 13 Old 05-06-2011, 04:34 PM
usmcdoc14's Avatar
I would get a master install kit unless your gear guys is really really really good. But its good insurance to replace everything anyway.
we are talking a full case detroit, right?
usmcdoc14 is offline
post #3 of 13 Old 05-06-2011, 04:50 PM Thread Starter
kevo's Avatar
yes its a full case autolocker,where do i get a good kit
kevo is offline
post #4 of 13 Old 05-06-2011, 05:32 PM
Slow and Low
Co4Lo's Avatar
I bet Marcus at RCO could get you a Master Install Kit. If not, Phil at Trail Duty can probably hook you up.
Co4Lo is offline
post #5 of 13 Old 05-20-2011, 08:31 PM
Joneszj's Avatar
Does anyone know the part number for a detroit locker for the rear NON-RUBI dana 44? I've been searching and searching and can't seem to find it. I'm trying to price this out and I see there are 2 different ones, from 3.73 and down and 3.92 and up. I've read you need the 3.73 and down even if you run lower gears (I run 5.13s). Not sure why, so if someone could chime in with an explanation that'd be great.
Also, if the dana 44 is 30 spline and I am looking at getting a lock-right or spartan (lunchbox style) locker, what carrier will I need to swap in? I've read all over different places and some say you need the 3.73 and lower carrier even if you run lower gears (Again, I run 5.13s). Is this true and if so, please help me to understand. Thanks.
1972 Commando on Tons & 40s
Joneszj is offline
post #6 of 13 Old 05-20-2011, 08:52 PM
Bosox5's Avatar
Detroit for our non rubi d44 is part # 187SL16D
That's what I have in mine with 5.13s, and it works great.
Sent from my ADR6400L using Tapatalk
Mike
USCG 04-Present
Just another JK on 35's
Bosox5 is offline
post #7 of 13 Old 05-20-2011, 08:53 PM
MadHatter's Avatar
On a Non-Rubi 44 you'll use a 187SL16D Detroit Locker with your 5.13 gears
Edit: Damn Mike, you're too fast.
Originally Posted by NGINIER View Post
Jeep's role in society is that they function outside of society.
MadHatter is offline
post #8 of 13 Old 05-20-2011, 08:57 PM
2k2wranglerx's Avatar
it's pretty difficult to press the old carrier bearings off without damaging them...
your pinion depth should still be close enough to work, but you'll need the outer carrier shims as well because you'll probably need adjust and reset the backlash. and you should also replace the ring gear bolts since they're notorious for stretching and backing out when they're reused.
good luck
2k2wranglerx is offline
post #9 of 13 Old 05-20-2011, 09:00 PM
MadHatter's Avatar
Also might have to drill the carrier on the detroit depending what your ring gear bolt size is. Detroits come with 3/8" holes I believe. Factory ring gear size is 1/2", and, obviously not sure what your 5.13s have
post #10 of 13 Old 05-20-2011, 09:18 PM
Bosox5's Avatar
Hey mad, yep I had too drill also...was kinda of freaked about it but it worked out. Great locker!
Mike
USCG 04-Present
Bosox5 is offline
post #11 of 13 Old 05-20-2011, 09:22 PM
i don't know what gears he has but my G2 gears were drilled and tapped for both size bolts
post #12 of 13 Old 05-21-2011, 12:05 PM
Dynatrac's Avatar
Usually they are drilled for 7/16" and 1/2". The locker is drilled for 3/8".
FWIW, unless something is damaged and needs replacing, you should NEVER have to change any pinion setup with a simple diff swap.
Dynatrac is offline
post #13 of 13 Old 05-21-2011, 08:29 PM
AReed's Avatar
Yup, you should never have to change pinion depth or anything to do with the pinion in a carrier swap. The need for a master install kit is way over kill. If a shop is doing it they should easily be able to re use the carrier bearings and should have some carrier shims laying around that they could use to set backlash.
Like us on
AReed is offline
