steering wheel shimmy at aprox 50 mph - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 05-05-2011, 09:41 AM Thread Starter
Constant shaking of the steering wheel right around 50 mph?
speed up or slow down 5mph and it stops
35" tires
3.5 lift
High steer kit
Jks track bar.
beilstien steer stablizer
39000k miles
not sure if a tire is out of balance or posibly ball joints, everything else seem tight.
What do you think?
storch is offline
post #2 of 8 Old 05-05-2011, 09:45 AM
TrailDuty.com
PhilD's Avatar
My first guess would be out of balance. Could be any number of other things, but I'd start with the simplest one first.
Have you tried rotating the wheels?
PhilD is offline
post #3 of 8 Old 05-05-2011, 09:49 AM
Breaker of nice things
merlin4979's Avatar
Yep - I'd agree with Phil. If it's speed-specific, then its usually a tire balancing issue.
merlin4979 is offline
post #4 of 8 Old 05-05-2011, 06:38 PM
x3 on the tire balance if its only at that specific speed
BBirish is offline
post #5 of 8 Old 05-05-2011, 07:15 PM
desert dog's Avatar
x4 on out of balanced tire. Dealt with that several times. At exactly 45MPH then it would go away at 48mph!
desert dog is offline
post #6 of 8 Old 05-07-2011, 06:48 PM
Same here had the shake at 50, once hit 55 no shake. After balancing all was good again.
08 Jk is offline
post #7 of 8 Old 05-07-2011, 07:26 PM
Slow and Low
Co4Lo's Avatar
You wouldn't happen to have Pro Comp tires would you? They wobble.
Co4Lo is offline
post #8 of 8 Old 05-07-2011, 08:01 PM
hogzilla's Avatar
x5 or 6 on the out of balance. I had the same problem, had 'em balanced AND rotated while they had them off the Jeep. Goodbye shimmy!
hogzilla is offline
