16x10 wheels for JK - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 05-05-2011, 01:07 AM Thread Starter
SoGa's Avatar
16x10 wheels for JK
Does anyone know of any 16x10 Black alloy wheels for a JK other than Pro Comp?
2011 4DR Rubi
rugged ridge fenders
38" KM2's on Pro Comp wheels
5.38 gears, Frt and Rear Ten Factory Axle shafts
2.5 RK Max Travel w/ Bilsten 5160's & 1.25 in body lift
c gussets, G2 Diff covers, & Poly Ball Joints
Metal Cloak stinger frt bpr w/ warn winch
Road Armor Rr Bpr
Going on soon!!
PSC Rocker Knockers
line-x tub
2005 Power Wagon on 35's
35" KM2's, XD Rockstar wheels, Tiregate, 2" lift, Frt lightbar
SoGa is offline
post #2 of 18 Old 05-06-2011, 07:28 PM
I have a set of 16x10's in a 5 on 5 pattern...there aren't too many options out there at all..I ended up with a set of polished pro comps in the design I liked and had them powdercoated.
Edit: sorry for uploading with phone.
http://[IMG]http://i1108.photobucket....jpg[/IMG]
Sent from my PC36100 using Tapatalk
sethrrogers is offline
post #3 of 18 Old 05-12-2011, 06:28 PM
Poseidon's Avatar
I was surprised to see KMC didn't have anything. Why do you want that size. It seems that if you are starting with the wheel, you can start over with a more common size.
Poseidon is offline
post #4 of 18 Old 05-12-2011, 06:31 PM
You know that a 17" wheel will give you a lot more tire options. This is coming from a guy that runs 15" wheels.
4x4x4 is offline
post #5 of 18 Old 05-13-2011, 06:50 AM
thebigtman's Avatar
Raceline/Allied
V8 YJ/TJ hybrid on tons
thebigtman is offline
post #6 of 18 Old 05-13-2011, 08:31 AM
Jaybee1669's Avatar
Some of the military take off require that size. Maybe he's looking to run Micheline XML's
Jaybee1669 is offline
post #7 of 18 Old 05-13-2011, 12:54 PM
I found a set of these 1069's sitting at a local wheel shop for $70 a wheel. After sandblasting and powdercoating it came to $105 a wheel. I had been eyeing the 365 KM2 for the price and was able to talk down the price on the km2's a bit more so I pulled the trigger. So i basically have the 38x14.50 km2 mounted on a 16...so reason was cost...
post #8 of 18 Old 05-13-2011, 12:57 PM
i did double check other tire options...interco makes there irock radial in a 41x16 so if i do decide to swap out sometime...the 41 or another set of 365's will prob be my option. I dont forsee the jeep running smaller than 37's..if so i guess ill be making a swap.
post #9 of 18 Old 05-13-2011, 04:04 PM Thread Starter
SoGa's Avatar
My reasoning for the wheels is the same as you mentioned to run the 365 KM2's
2011 4DR Rubi
Road Armor Rr Bpr
Going on soon!!
PSC Rocker Knockers
line-x tub
SoGa is offline
post #10 of 18 Old 05-13-2011, 04:30 PM
desert dog's Avatar
Why not run a narrower wheel. 10" is pretty fat, even for those.
desert dog is offline
post #11 of 18 Old 05-13-2011, 09:58 PM
Joneszj's Avatar
You think 8" would be too narrow for the 365s?
They are supposed to measure 14" wide. In that respect a 10" wheel isn't so bad.
And I have no clue where you could find a 16x9 wheel. I've been toying with the idea of mounting the 365s on my current 16x8s. I know poor mans beadlocks are wide tires on narrow wheels, but this width combo might be pushing it as far as being very hard to balance and needing to run really low pressure on the street to ride correctly.
1972 Commando on Tons & 40s
Joneszj is offline
post #12 of 18 Old 05-13-2011, 11:45 PM
VKS Fab
JK Vick's Avatar
Im running the km2's 345's on a 16x8. IMO that's the widest tire I'd wanna run on an 8.
Vick
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #13 of 18 Old 05-14-2011, 02:00 AM
desert dog's Avatar
My bad. For some odd reason, I thought you had 345s. Yea, I think you might be stuck with ProComps for 5x5, unless you want to try the ATX in 16x9.
post #14 of 18 Old 05-14-2011, 11:56 AM
Chinpokumon's Avatar
I run those ProComp 16x10s and love them! I also got the trim ring to change up a very common wheel. The tires I chose were the Good-Year DuraTracs and am totally pleased with them as a daily driver.
This pics wasn't supposed to be of the tire and wheel, but it's pretty clear. I know you were asking for alternatives, but to me as soon as I added the trim ring - it gave a TOTALLY different look.
2010 Bright SILVER Sahara JK 6spd, 3.73's, Tow Package, Dual Top
4" Superlift w/Bilstein 7100's front / Bilstein 5100's rear; Goodyear DuraTracs 315/75/R16 on 16x10s; Bilstein Steering Stab.; Clayton Upper CA's; Adj. Frt&Rr Trackbars; Rock Krawler rear shock relocators (trimmed hangers); BodyArmor Ft Bump; Crown SS extended fr & rr lines; Viper TB; Diablo Tuner; Plate relocate w/LED; AFE filter; 20% tints
Chinpokumon is offline
post #15 of 18 Old 05-14-2011, 12:03 PM
black rock makes some in a 16x10 but i think in steel only.
Mt.GoatJK is offline
post #16 of 18 Old 05-14-2011, 01:38 PM
BenFoo's Avatar
Youll need a backspacing of 3.5" or less if you plan on running a 14.5" width tire on the.....
Sent via Telegraph.
BenFoo is offline
post #17 of 18 Old 05-16-2011, 09:06 AM
Hey, could I see some pics of those 38's??
5.13 gears, 37" KM2's on Stock 18" rims, 1.5" Spidex spacers, 2.5" Teraflex BB with shocks, Teraflex steering stabilizer, space tire reinforcement and relocator kit, JKS adj front and rear Trackbars, 19's and 60's springs off 4 DR Rubi Unlimited hardtop ( gave me an extra 1" in front and 1.3" in the rear) Red's trimmed flat fenders, RC 1.25" Body Lift!
04sssti is offline
post #18 of 18 Old 05-17-2011, 11:35 AM
Not mounted yet but will be soon.
