Speedo vs Nav - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 05-02-2011, 09:32 PM Thread Starter
stevej21's Avatar
Speedo vs Nav
So, I got my lift, 5:38's and 37's all finished up yesterday. During my test drive, I knew my speedo would be off, but I figured I would just use the nav system for my mph until I get my DS trinity installed. Turns out I was wrong, the nav system is off just as much as the speedo. Does this make sense to anyone? I figured the nav's mph would have it's own signal like a normal gps. Anyone else have this issue?
stevej21 is offline
post #2 of 12 Old 05-02-2011, 09:59 PM
coilrod's Avatar
I noticed my stock set up was about 4 % off at 100 by gps. Then I put on 37's and at one point had the stock size programmed. The speedo was off 15% at 100 and the shifting was screwed.
Your speedo should be way off until you reprogram, but the nav system might us canbus for speed so that might be why. Canbus for everything is scary.
The 2011 should be pure garmin.
Anybody?
coilrod is offline
post #3 of 12 Old 05-02-2011, 10:13 PM Thread Starter
stevej21's Avatar
Mine is a 2011 and the speedo and nave were 1 mph different stock. Now that still seems to be the case, except they are both 9-10 mph slow at 65mph. And I'm pretty sure it's garmin for the gps
stevej21 is offline
post #4 of 12 Old 05-02-2011, 10:22 PM
axsys's Avatar
First, coilrod, your Jeep goes 100?
Second, are you guys all in 2011s? Because my Nav doesn't show my speed.
Third, my speedometer is dead accurate after adjusting my programming via Superchips
axsys is offline
post #5 of 12 Old 05-02-2011, 10:47 PM
coilrod's Avatar
I can do 100 into a head wind. (Avenger Supercharged 2010 Rubicon Un-ltd no nav, just a garmin) and yes, that's mph,not kmh. It just takes more fuel...
It must be the canbus feeding the nav system off the wheen speed sensors if you still haven't reprogrammed the tire size.
Unless you are driving a stick your auto trans shifting should be off.
Last edited by coilrod; 05-02-2011 at 10:49 PM. Reason: did not type all the words
coilrod is offline
post #6 of 12 Old 05-02-2011, 11:04 PM Thread Starter
stevej21's Avatar
I will be putting in the programmer pretty soon, I just thought it was odd that the nav was off like the speedo. To me, that just doesn't seem right.
stevej21 is offline
post #7 of 12 Old 05-03-2011, 04:57 AM
block's Avatar
yup the nav is getting the speed from the vss ( vehicle speed sensor ) so until you reprogram your gps speed will also be off.. if you used a hand held gps that would give you accurate speed.
block is offline
post #8 of 12 Old 05-03-2011, 07:45 AM
razzer's Avatar
or do like i did, get an aftermarket dvd/gps unit ... lol my gps is right on all the time ....hehe but yes that makes sense that the factory gps uses on board signal
There is no such thing as "one too many" ... and there is no such thing as a "finished jeep" project
razzer is offline
post #9 of 12 Old 05-03-2011, 08:22 AM
All our Jeeps "can" do 100. That's where the speed governor is. Its just a matter of how much each one of us wants to explain all the perverted shit we did to the devil when we do go 100 and wreck our shit.
JaysJK is offline
post #10 of 12 Old 05-03-2011, 12:57 PM
venom's Avatar
actually, at least in 07 - the limiter was set to 98 MPH from the factory...
well dash said 100, gps said 98.
Originally Posted by My Wife
venom is offline
post #11 of 12 Old 05-03-2011, 01:27 PM
SoCal147's Avatar
1. 100 mph...Are you freakin kidding me.
2. Installed KM2 35's (34.5") off a little. Corrected with SC. Not perfect because I corrected for 35" not 34.5" and I am Lazy.
3. Installed 5.38 gears. Not much difference. Wierd
All speeds were checked with a Garmin. 1-3 MPH difference dont mean much when your doing 150.
2009 JK Rubicon:
SoCal147 is offline
post #12 of 12 Old 05-03-2011, 01:55 PM
venom's Avatar
Gears won't effect your speedo
Canbus reads the wheel speed sensors in the hubs
Scratched into the wall with a dead iPhone.
venom is offline
