coilovers? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 04-30-2011, 08:14 PM Thread Starter
O2BDrty's Avatar
coilovers?
Is there a shock system that takes the place of your coil springs and you relocate and cut your existing shock brackets?
I'm sure I'll think of something
O2BDrty is offline
post #2 of 16 Old 04-30-2011, 08:27 PM
Dr.Dirty's Avatar
Feedback: 21 reviews
There are a few Coilover kits out there. What exactly are you looking for?
Dr.Dirty is offline
post #3 of 16 Old 04-30-2011, 08:39 PM
Having to cut your vehicle up to make coilovers work is a road many wheelers don't want to go down. So far there isn't a system for what you are looking at doing.
Because of that our system is designed to bolt right in place without having to make any permanent modifications to your JK.
Our system consists of bolt on front and rear brackets - even your front factory spring bucket is retained for optional hydraulic bump stops.
http://www.rebeloffroad.com/product_p/roe-ccc.htm
REBEL OFFROAD is offline
post #4 of 16 Old 04-30-2011, 08:39 PM Thread Starter
O2BDrty's Avatar
Was wanting to do away with my existing shocks and mounting brackets and just use the coils it comes with already
O2BDrty is offline
post #5 of 16 Old 04-30-2011, 08:50 PM Thread Starter
O2BDrty's Avatar
Can't use the rear option. I'm putting in a Gen-Right duel gastank. What other options do I have?
O2BDrty is offline
post #6 of 16 Old 04-30-2011, 08:53 PM
Dr.Dirty's Avatar
I ran the Rebel set up, it wanst the setup for me. It took up way to much valuable spce in the fender well.
Sucks you ask for some input and get hit with BAM buy this....... I thought Krawl was in here for a minute.
Dr.Dirty is offline
post #7 of 16 Old 04-30-2011, 08:56 PM
Dr.Dirty's Avatar
Sounds like your looking to just mount your shocks inside of your existing coil springs much like alot of the late model trucks with IFS. I havent seen a kit for this so youd be looking at custom stuff and i dont think you will gain a whole lot fo anything going that route.
Dr.Dirty is offline
post #8 of 16 Old 04-30-2011, 08:58 PM
Chris Hansen's Avatar
I've been following dirtys coil over installs, he knows what he is talking about. Here are a few links for you.
https://jkowners.com/forum/showthread.php?t=45070
https://www.jkowners.com/forum/showthread.php?t=45257
Dirty's Minions don't officially exist. They are a myth, a bedtime story, a whispered rumor. They are ghosts.
Chris Hansen is offline
post #9 of 16 Old 04-30-2011, 08:58 PM Thread Starter
O2BDrty's Avatar
Looking to free up some space where my rear shocks are. Just don't know what to do.
O2BDrty is offline
post #10 of 16 Old 04-30-2011, 09:00 PM
Dr.Dirty's Avatar
Ill see if i can find the thread, I belive usmcdoc outboarded his shock on his rig
***** take a look at this link *****
https://www.jkowners.com/forum/showth...+shocks&page=2
Dr.Dirty is offline
post #11 of 16 Old 04-30-2011, 10:34 PM
Bandit's Avatar
Running shocks in the standard coils would mean considerably less travel but horses for courses I guess...
From the investigation ive done outboarding the rear means running very low backspacing/spacers and/or close to full width D60's to provide enough space unless you plan on cutting the chassis. Or maybe if you stuck with skinny tread and spacers.
Dr Dirty, are you talking about the extreme kit as opposed to the bolt on rear kit?
Cheers,
B.
2011 4DR CRD conquering a gutter near you
Bandit is offline
post #12 of 16 Old 04-30-2011, 11:11 PM
terrahawk's Avatar
You are talking about more of a strut assembly, but I don't understand what the shocks in the stock location get in the way of the make you want something like that.
terrahawk is offline
post #13 of 16 Old 05-01-2011, 08:17 AM
JKDinker's Avatar
Terrahawk, if my memory serves me right you outboarded your coilovers didnt you? Can you post up a pic? Redoing my junk as well. Thanks!
JKDinker is offline
post #14 of 16 Old 05-01-2011, 09:48 AM
Slow and Low
Co4Lo's Avatar
Are you referring to me?
Co4Lo is offline
post #15 of 16 Old 05-01-2011, 10:19 AM
Dr.Dirty's Avatar
Nope..... that was for Rebel.......
Dr.Dirty is offline
post #16 of 16 Old 05-01-2011, 12:07 PM
Slow and Low
Co4Lo's Avatar
Co4Lo is offline
