alignment with dana 60s - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 03-24-2020, 03:29 PM Thread Starter
Just upgraded to the Mopar 60s with 40 inch Goodyear's and hydro assist. Steering is all over the place. What is the best caster and toe settings for those that have upgraded axles to get it to drive nice?
2012 Jeep Unlimited Rubicon Gecko Green!
6" longarm, 40" tires, 4:88's Synergy inner/outer sleeves, trussed, c's and hvy duty ball joints,Tom Woods DS f/r, Bush Whacker Flat Fenders.
RSE Rear Bumper, Smitty Stinger front.
ShizNizy is offline
post #2 of 7 Old 03-24-2020, 03:53 PM
you can go piss up a rope
snout's Avatar
About 350 degrees.
y’aller quenchin' with beer
snout is offline
post #3 of 7 Old 03-24-2020, 05:11 PM
rich6700's Avatar
Just set it to the stock jk settings.
rich6700 is offline
post #4 of 7 Old 03-25-2020, 07:10 AM
Castor I set them at 6-8*, toe try 1/8"+-.
CT Performance, Inc is online now
post #5 of 7 Old 03-25-2020, 11:59 AM Thread Starter
Thanks. Ive been googling elsewhere and someone said they were at 5 degrees. Tried that and its a lot better. I'll let my guy know you are having luck at 6-8. I daily drove the jeep for 4 years before daily driving my 6 door truck for 2 and then been in my GC SRT8 for the last 1.5 but want to start driving the JKU a little more and have to make it drive nicer.
ShizNizy is offline
post #6 of 7 Old 03-25-2020, 12:26 PM
6-8 degrees of caster is a lot for the dana axles with a 6" lift. Driveshaft bind and clearance might be a concern and something to check if you go that route. You can at least lock it out so vibration at that angle would not be an issue on the highway in 2WD.
thedirtman is online now
post #7 of 7 Old 03-26-2020, 10:47 AM
GR1P's Avatar
Yeah there's no set number to shoot for with pinion/caster. Every setup is different. I run max caster before getting vibes with the front hubs locked on the UD60s. Of course I daily with the hubs unlocked and it rides great.
Toe set to 1/8"
GR1P is offline
