My brother in law has an 09 JKU Rubicon: factory axle 4" lift on 37s. His stock ball joints went bad so he replaced them with the Teraflex joints. It was about a year ago (summer 2018 I believe). The passenger side lower joint is bad again. He has only wheeled it one time in that period. It was light wheeling, mainly just dirt trails and a few rocks. What would cause it to go out so quickly? I guess that is my opinion though (but shouldn't a TF ball joint last longer than a year and a half with mostly on road driving). It is his daily driver. The passenger top and both top and bottom drivers all seem tight. Just the pass lower is showing movement. Thoughts?
I guess that's how teraflex does it. Others I have done torque the top to 30-35 then the bottom to spec then the upper to final spec. This insures you get the proper even torque on the bottomed top ball joints. If you do one then the other the first may not actually be up to spec.
Yeah when I saw the top joint has lateral movement that blew my mind. TF has a video that shows that it is normal. Strange in my opinion. We're going to replace the upper and lower on pass side and talk to TF about it. I'll try to post our findings.
I just adjusted the pre load on mine (pre2017 models). But either set as they start to ware out you just get in there and set the preload again. Mine are the top adjustable and take a $10 tool from TF. Then torq to 90in lbs I think. Made a hell of a difference.
Can anyone get me a measurement of the inner C opening? Or in other words, from the bottom side of the top of the C to the top side of the bottom side of the C. Gussets were welded on and I want to see if the inner Cs opened or closed up during that process. His is a Rubicon so it's a D44, but it should be the same as a D30. Thanks in advance.
On the JK axles, only the lower ball joint is load carrying. The upper is a pin "follower" style ball joint that plunges up and down to account for any differences in distance between the ears of the C's. The lower ball joint controls vertical movement, and the upper ball joint controls lateral movement.
For both ball joints to be load-bearing, there must be a method to adjust for variances in the distance between them. The older YJ axles used a threaded insert in the C and the new JL ball joints use an insert similar to D60's.
I have gone through 5 sets of ball joints with 52000 miles on my 08. The 37" tires and 4.5" backspacing on the wheels is hell on the ball joints. I went through two sets of Dynatracs which lasted about 8k miles. On Teraflex and now I grease the lowers every time I change oil in hopes of extending their life. Front end needs to be jacked up when greasing.
Related Threads
JKOwners Forum
2M posts
62.8K members
Since 2007
