Help with figuring out my JK lift - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 10-08-2019, 06:18 AM Thread Starter
Just purchased my first Jeep, a 2012 JK and looking to put on new 285/75R17 BFG KO2ís, but was worried they would rub. The current wheels are 255/75R17 and I think the wheels are the Ultra Performance Bolts. Based on the way it all looks visually, it seems like thereís a ton of room.
I took some measurements and wanted to see if you guys could help confirm the lift off of stock and whether or not the KO2s would a) fit without rubbing on or off trail and b) that they would look good.
Appreciate the help!
MaCheFai is offline
post #2 of 9 Old 10-08-2019, 07:32 AM
JeeperJoe's Avatar
Looks like you have about a 2.5inch lift. The tire size your looking at should fit without any issues depending on the backspacing of your wheels. Make sure to swing by the welcome room and introduce yourself!
You can have a savings account or a Jeep.
JeeperJoe is offline
post #3 of 9 Old 10-08-2019, 08:30 AM Thread Starter
Thanks so much for the quick reply. Just so I can learn, can you help me understand how you determined that?
Also, what size backspacing would the new tire require? I believe my wheels are the ultra motorsports 198 Bolt wheel. I'd post a link, but the forum won't let me. :/
MaCheFai is offline
post #4 of 9 Old 10-08-2019, 01:20 PM
JeeperJoe's Avatar
The measurement in your first pic would measure about 18.5" on a stock jeep so there's your 2.5" lift. As far as wheels go, usually 4.5" of backspacing is the happy spot for 35's. The wheels you have are around 4.9" BS and the tires are close to 34's so what you have might work fine. Put them on and see. If anything you might rub on the frame rails at full lock. If that's the case you can either get different wheels or through on a hub-centric spacer.
post #5 of 9 Old 10-09-2019, 06:05 AM Thread Starter
Thanks so much, ordered from tirerack last night. 🤞
MaCheFai is offline
post #6 of 9 Old 10-15-2019, 06:57 PM
May be too late, but want to put in a plug for the 34x10.5-17 size KO2 tires. Load range D is a bit more comfortable than the load range E 285x75's. Fit on my 2015 2door with stock wheels & just a thinest wheel spacer on the fronts only. Good for 50,000 miles. Ordered a new set yesterday. Will be ready for winter.
MntrsJeep is offline
post #7 of 9 Old 10-18-2019, 07:56 AM Thread Starter
Ah shoot, wish I would have seen this prior. It's all good though, got the wheels balanced and installed and it made a huge difference, aesthetically, noise wise and comfort of drive. So I'm definitely happy.
I was going to get the spare, but curious to hear if people have any fitment issues on 34"?
MaCheFai is offline
post #8 of 9 Old 11-06-2019, 05:06 PM
I got the 285/75/17 KM2ís, and the spare fits fine without rubbing. I run AEV rims, 5.2 backspace, and finally installed the teraflex tailgate hinge kit. But honestly, the tire and rim did not affect my old tailgate one bit, over the past 40k miles. But sshh, donít tell the wife....
2011 JKU L83 V8
Mjp83 is offline
post #9 of 9 Old 11-07-2019, 09:03 AM
Just to let you know your suspension is set up very poorly. Looks like someone sold/traded this thing in with factory parts after running it with different components. Clean that thing up good and put some paint on it to keep the rust from getting any worse. Then find someone that knows about suspensions and have it set up right.
