One wheel pointing inwards - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 10-06-2019, 06:44 AM Thread Starter
After installing the Teraflex drag link , tie rod , track bar and Tera 44 axle one of my front right wheels is more inwards compared to other. Is there a sequence to adjust the 3 steering components? What’s the best way to make tyres straight considering the left wheel is already straight, axle recentered and steering wheel straight
JK07 is offline
post #2 of 4 Old 10-06-2019, 10:36 AM
Sounds like you have way too much toe-in. Google how to set your toe, it's an easy tie-rod adjustment and you can do it yourself with a tape measure.
christensent is offline
post #3 of 4 Old 10-06-2019, 05:41 PM
BigTB's Avatar
First, set the toe. The toe is set by adjusting the tie-rod.
Next, center the axle by adjusting the track bar.
Finally, center the steering wheel by adjusting the drag link.
BigTB is offline
post #4 of 4 Old 10-07-2019, 08:21 PM
Rockhumper's Avatar
Cheat
Measure your old drag link , track bar, and tie rod ..... it痴 a great start then adjust from there. Good luck
覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧-
Rockhumper is offline
