Adjustable Ball Joints - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By PIG
post #1 of 6 Old 09-13-2019, 11:34 AM Thread Starter
AllJumpStyle's Avatar
Synergy MFG's new Adjustable Ball Joints are now out! They are available in both knurled and non-knurled versions.
https://www.synergymfg.com/synergy-j...joint-kit.html
After 5 years of development and over 100,000 test miles our Heavy Duty Adjustable Jeep JK Ball Joints are here! This is the last set of ball joints you will ever have to buy. Limited Lifetime Warranty. Tighten up your steering for good with our patent-pending (# 16/020894) design which is fully adjustable, serviceable, and rebuildable without having to press the ball joints back out of the axle end forging yokes (C's). These ball joints never have to come back out. Available in knurled and non-knurled versions to fit all vehicles regardless of what type of ball joints were installed previously. Lower ball joint bearing surfaces are CNC machined from 4140 steel, heat treated, induction hardened, and ferritic nitrocarburized to make these the longest lasting, longest wearing ball joints on the market. Kit includes all 4 ball joints to service one Jeep and the adjuster tool for adjusting the preload on the lower ball joints.
Fits:
07-18 Jeep Wrangler JK/JKU
99-04 Jeep Grand Cherokee WJ
Benefits:
Tightens sloppy steering
Designed to last the life of the vehicle
Never need to replace ball joints again
Best in class price/performance ratio
Features:
Kit includes all 4 ball joints and lower ball joint adjuster tool
Patent Pending lower ball joints are adjustable so they always have the correct amount of preload
Knurled and non-knurled ball joint housing options to fit any vehicle
Lower ball joints are rebuildable on the vehicle without removal
Lower Ball Joint bearing surfaces are CNC machined from 4140 steel, heat treated, induction hardened, and ferritic nitrocarburized for extreme wear resistance
Low profile dust boots are made from thick nitrobutile rubber (NBR) to protect the joint from contaminants and eliminate any chance of tearing
Zerk fittings included for trouble-free maintenance
Notes:
Synergy 4119 High Performance Grease recommended
Knurled ball joints required when replacing knurled ball joints that have enlarged the axle end forging bores
Non-Knurled ball joints recommended for replacing non-knurled ball joints
Compatible with RCV axle shafts
Chris Steimle
Product Manager
AllJumpStyle is offline
post #2 of 6 Old 09-14-2019, 12:38 PM
Fklein6768's Avatar
What's the kick off sale price?
www.4x4s-pod.com
Fklein6768 is offline
post #3 of 6 Old 09-14-2019, 11:12 PM
you can go piss up a rope
snout's Avatar
More than what Eddie and Jeffery paid
y’aller quenchin' with beer
snout is offline
post #4 of 6 Old 09-16-2019, 09:52 AM
PIG
PIG's Avatar
Hit me up and ill see what I can do for you!
[email protected]
Fklein6768 likes this.
PIG is offline
post #5 of 6 Old 09-16-2019, 11:59 AM
Fklein6768's Avatar
[email protected]
Will do
www.4x4s-pod.com
post #6 of 6 Old 09-16-2019, 03:44 PM
