Front pinion angle - measuring against the frame - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 08-25-2019, 12:08 PM Thread Starter
rockystock's Avatar
Screwing with my front pinion angle today. I'm using both a bubble level and a phone app (Clinometer, works well actually). With the app, I can "calibrate" or set the zero against any angled straight surface.
Questions for you all: how do you get your reference "zero" to measure the pinion angle? I know most just say "park on level floor" but I don't want to trust that the floor is level enough. I used the clinometer app to set zero to the frame rails (middle of jeep, under doors) and then measured the pinion. Second question: are the lower frame rails designed to be level to the ground?
rockystock is offline
post #2 of 6 Old 08-25-2019, 05:30 PM
ronjenx's Avatar
Pinion angle is the angle of the pinion axis compared to the drive shaft axis. Frame rails, floor level, don't matter.
ronjenx is offline
post #3 of 6 Old 08-25-2019, 06:43 PM Thread Starter
rockystock's Avatar
Sorry, I should have added that I was also trying to adjust caster. I know that stock caster is 6 degrees, making the pinion angle zero at normal ride height.
post #4 of 6 Old 08-25-2019, 07:10 PM
ronjenx's Avatar
I suspected that, but took your post at face value.
Stock caster for the 2008 JK is +4.2, 0.5, with max left/right difference 0.65.
Messing with caster at home is best done after you get the caster angle from an alignment machine. Then you can keep track of how many degrees you change it by putting an inclinometer on a flat surface on the axle. If you keep a record of the changes you make, the levelness of the frame and floor still won't matter.
The reason you should get the initial caster angle from an alignment shop is caster can't be directly measured. It is obtained from measuring how much the wheels tip when they are turned from side to side.
ronjenx is offline
post #5 of 6 Old 08-25-2019, 10:06 PM Thread Starter
rockystock's Avatar
Agreed - thanks. Yeah I'm just getting an initial caster to get it to the alignment shop.
post #6 of 6 Old 08-26-2019, 04:30 AM
Chipewa's Avatar
Rough caster angle can be calculated by using an angle gauge on the flat on top of the steering knuckle and the flat on the pinion flange. See attached pic for concept.
LS3 2007 JKU X - Red Rock, 2012 JKU Rubicon - Deep Cherry Red, 2001 TJ - Black
Chipewa is offline
