Part # for Brake Caliper Bracket to go to 13" rotors? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 08-12-2019, 12:18 PM Thread Starter
I have a stock 2013 JKU and I just ordered a new front set of ceramic pads and rotors from Brakelabs. When the rotors showed up they were 13"(332mm) and my stock rotors are 12"(302mm)(description said direct replacement and I have never had it apart before). The pads fit my caliper, but the caliper brackets need to be replaced to fit the 13" rotors. I have done a little research on stock replacement parts and I see some notations of OEM non HD 12" and OEM Heavy Duty 13" rotors.
My question is: does someone know of a factory or aftermarket front caliper bracket for 13" rotors? Maybe even from another Mopar, Ram Truck, etc.
Or is the bracket/caliper the same for both and the HD knuckle is different?
My Jeep has stock tires and I don't see a need to swap out the master cylinder and calipers. I just figured I would help it out a little if possible before I return these rotors.
Thx G
WILDTHANG is offline
post #2 of 3 Old 08-12-2019, 07:50 PM
Something from Crown Automotive may do the trick. Parts 68157610AA and 68157611AA. Designed for Crown's Big Brake Kit which has 13" rotors. Double piston design is nice. Entire kit is part #RT31046 for further reference. Uses Ram 1500 pads, so easy to get.
Schlieko is offline
post #3 of 3 Old 08-13-2019, 06:14 PM
SweetCJ7's Avatar
100% ^^^^^ Here is that kit. Savings in cart.
Allen's Offroad - 530-620-1100
Email me at:
FREE SHIPPING on orders of $99.99 or more.
SweetCJ7 is offline
