TPMS Light - Need help. Tried lots of fixes - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By rich6700
post #1 of 12 Old 07-04-2019, 06:27 AM Thread Starter
I bought 2013 JKU for my 18 year old daughter from one of my best friends. The JKU has about 50,000 miles and was customized with a lift, 34" tires and 22" wheels. We bought a few weeks ago knowing I needed to put some new tires on it soon. My daughter put about 500 miles on it with no issues and I decided to go ahead and get the new tires before she goes off to college.
The tire pressure light on the dash came on a day or so after installing the new tires. Checked the tire pressure on all 5 tires and all was good. Took it back to the tire shop and they reset the light (yes they were surprised they could reset it because they even knew that normally you have to drive it for 10 minutes or so for it to reset). It stayed off for about 20 miles then was right back on. I then took it to a different tire shop (because mine was closed), they checked the sensors in all 5 tires and they all were shows the sensors were transmitting and the batteries were ok.
So this week, we were going out of town so I left it at my tire shop again and they reset the light and reprogrammed the sensors and drove it a couple of days. They thought they had it fixed all though they were puzzles why they could reset the light without driving it. I picked it up this afternoon and drove about 20 miles and the light is back on.
If this was my jeep I wouldn't worry about it but since it is my 18 year old daughters, I would really like to get it back working before she is running the roads back and forth to college.
I did buy a programmer and adjusted the psi threshold when the light should come on and that didn't help either.
Anyone seen this behavior before and have any idea what I should try to fix it?
Thanks for your help
whitlecj is offline
post #2 of 12 Old 07-05-2019, 06:57 PM
a few questions
1) does it have the Enhance dash display to show the actual tire pressure? if so are they all displaying? it will come on if there is too much pressure just as quick if it has too little pressure in the tires
2) what programmer are you using to set the threshold on the TPMS?I had a super chips on my 2014 but if I remember correctly somewhere along the use of it they took away the ability to set exact pressures and made it just kill the warning light instead.
Tspevacek is offline
post #3 of 12 Old 07-06-2019, 07:40 AM Thread Starter
Originally Posted by Tspevacek View Post
a few questions
It does not have the enhanced display. I used the app OBD Jscan to adust the pressures. I have no idea what to try next
whitlecj is offline
post #4 of 12 Old 07-06-2019, 05:29 PM
rich6700's Avatar
It's the 22 inch wheels. The jeep is rejecting them.
funfred likes this.
rich6700 is offline
post #5 of 12 Old 07-06-2019, 10:54 PM
I am willing to bet at least 1 of the tire pressure sensors is damaged.
post #6 of 12 Old 07-07-2019, 05:45 PM
Mguesto's Avatar
Make friends at the Jeep dealer service counter. I had the same problem on my 09 X and his handheld device fixed my problem
again had to drive it longer than normal for the light to go out but once it did go out. it stayed out.
5 weeks ago.
wish you luck
Matt
Mguesto is offline
post #7 of 12 Old 07-10-2019, 06:05 AM Thread Starter
Thanks for the response. It was working with the same 22" wheels for approximately 50k miles so I do not think that is the case.
whitlecj is offline
post #8 of 12 Old 07-10-2019, 06:07 AM Thread Starter
I am beginning to think you are right. Had to be damaged when they put the new tires on even though they all show as good. Not sure how to get the tire shop to find the problem.
whitlecj is offline
post #9 of 12 Old 07-10-2019, 06:08 AM Thread Starter
5 weeks ago.
wish you luck
Matt
Can you give me more info on the handheld? I am willing to go try anything at this point. Thanks!
whitlecj is offline
post #10 of 12 Old 07-10-2019, 06:37 AM
Pmedic920's Avatar
Iím thinking like was mentioned above, one or more of the sensors got damaged during the new tire swap.
If your actually willing to try ďanythingĒ, and you truly want the issue resolved for your daughter, bite the bullet and just order 5 new sensors.
Personally Iíd take it back to the original shop and have them do the install. When it fixes your problem you may get them to (not) see the light, and they may wave the install fee.
Good luck.
Pmedic920 is offline
post #11 of 12 Old 07-10-2019, 08:58 AM Thread Starter
Good luck.
This is exactly what I am going to do. I talked to them this morning and I am going to supply the new sensors and they are going to put them on for free. Hopefully it takes care of it.
whitlecj is offline
post #12 of 12 Old 07-11-2019, 06:24 PM
Mguesto's Avatar
When i visited my dealer and had the light on. He brought out a hand held device and pointed at each tire. Some of my sensors were the wrong ones for my 09 JK They were putting out on the wrong frequency. and one tire reported having 164 pounds of air pressure in them. Had them install the correct ones and they used that device again to get them registered with my Jeep.
Seems the previous owner or the dealer i bought from swapped wheels and tires from a 12 or later jeep which is on a different frequency.
i believe the new sensors cost me 78 each plus remounting and balancing. The dealer i bought from picked up the tab. (WOW)
all is fine now. The device looked like a larger than normal odbII
Matt
Mguesto is offline
