Spartan locker in stock Dana 30 carrier ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 06-10-2019, 05:53 AM Thread Starter
Wolfy's Avatar
Hey everyone, I have a 2015 JKU Willy's so I have 3.73 gears.
I ordered a Spartan locker for my front Dana 30. I am now hearing that you need a different carrier for the Spartan locker because it will not fit in the factory Dana 30 carrier? And I heard that with Aussie lockers you can use the factory carrier? If this is the case I will order an Aussie and return the Spartan. Can anyone clear this up for me?
Thank you for any help!
-- Phil
2015 Unlimited Willy's Wheeler
Wolfy is offline
post #2 of 4 Old 06-10-2019, 06:18 AM
Did you try contacting spartan?
post #3 of 4 Old 06-10-2019, 06:27 AM
my advice:
Skip directly past that autolocker & contact Aussie / TorqueMasters as they actually have the appropriate JK/JKU carrier thrust-washers that do not require you to use an '06 or prior D30 carrier .
They have the Aussie locker & the TorqLocker for your JKs D30. Tell Cora that Jeffery from jko referenced ya....
You will be much more pleased if you do so.
post #4 of 4 Old 06-10-2019, 07:38 AM
Aussie/torq have unrivaled customer service and support. Not to mention quality product with insane warranty.
As for the carrier break, I believe it is 3.73 and lower you need a new carrier, 3.92 and up is a different carrier. **Just what I've read; I'm not a pro.
2nd edit; of course dirtman is right and spartan will have your answer.
libordemise is offline
