15 JK redoing front end/ Drag link problem - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 05-26-2019, 12:13 PM Thread Starter
After 2 failed outer tie rods/alignments figured out my driver side steering knuckle was shot.
So after getting raped for years taking my vehicle to mechanics and having nothing but problems, it's time to start doing the work myself.
Here's where I'm at.
current setup
Yeti tie rod,AEV 3.5 DS lift with Bilstein 5160 reservoir shocks, adams driveshafts.3.73 gears, and OME steering Stabalizer, on 35x12.5's.
I'm replacing u joints(dana Spicer), 4 Ball joints(moog Greasable), driver side spindle, new wheel bearings, and a moog pre assembled steering linkage.
While I was removing the AEV high steer drag link (which was binding up) the bolt just snapped right off. So yesterday when I got the bolt out if the knuckle I noticed my knuckle has been reamed out. this is one of the older models were the fitting was not greasable and had to be reamed out. Can't win here!!! I got a lot of worms out right now, and just opened another can.
anybody make sleaves to bring back to stock size ? It might be cheaper/easier to get another high steering drag link then to replace another knuckle. Any advice to get things going right at a reasonable price appreciated.
Hope to clean the bilsteins, the OME SS, and install new lower control arms.
Readytworoll is offline
post #2 of 2 Old 05-26-2019, 12:53 PM
yes steersmart (yeti) makes the sleave so you can use the yeti 26 which is stock size and what aev uses now.
Jadmt is offline
Similar Threads
Passenger knuckle with insert for drag link flip, flipped drag link SGT. Jackalope For Sale - Jeep parts 4 07-20-2015 06:33 AM
07 JK Drag link rod end scrapes frame (pitman arm end) billybob535 Stock JK Tech Dept. 4 08-27-2013 07:13 AM
front end track bar drag link help deekum1627 Modified JK Tech Dept. 27 06-03-2010 07:32 PM
Drag link, knuckle end, removal ? riverzendz JK General Discussion 11 04-14-2010 10:41 AM
Drag Link End yo77 Modified JK Tech Dept. 0 07-16-2009 11:36 AM
