Wheel Speed Sensor Problem - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 05-23-2019, 04:42 PM Thread Starter
2010 Jeep Rubi, 4" lift, 35" tires, stock axlesHad a code and esp/traction control light coming on. Code called for bad wheel speed sensor right front. Jeep drove ok, just the lights on the dash and the code. Changed the hub and cable. Now when braking, the abs goes crazy and the Jeep is pulling hard left when braking. No codes but esp/traction, abs going crazy, and pulling hard left. Thoughts??
18 JKU Granite Crystal- 4"lift, 40s, UD60s
07 Red Rock Crystal JKU - Sold
RedRock0740 is offline
post #2 of 8 Old 05-23-2019, 04:47 PM
Just dont cut the lines. Replace them.
libordemise is offline
post #3 of 8 Old 05-23-2019, 05:11 PM Thread Starter
Lol. I remember reading that you did that. Thanks man.
post #4 of 8 Old 05-23-2019, 06:36 PM
You know I cut mine because I had just installed a lunchbox locker and was getting that crazy sharp pull to the left and I had to eliminate the abs as a cause. It turns out I had the locker set up correctly and misdiagnosed the sensor issue as the locker which caused me to rip apart my front end like 6 times.
post #5 of 8 Old 05-28-2019, 04:49 PM
Disconnect the negative terminal for about a half hour. Plug er back in and see if things are reset. Also, when I replaced mine, I had to really makes sure the plug into the sensor was seated correctly for things to go back to normal. Good luck
Eggo17 is offline
post #6 of 8 Old 06-12-2019, 10:48 AM
I had this exact issue. The wheels speed sensors need to be an almost exact match DS/PS or you will have variances in the readings and shit like that will happen. Remove your other wheel speed sensor from the hub and clean the mount surface of rust or anything. Sand/file that baby smooth and plug it back in.
The minute amounts of rust, dirt, and oil that build up between the hub and surface of the wire plug make a big difference and both sides need equal spacing between of those wires.
I did this but couldn't get both sides "in sync" so I just replaced the other old but still functioning hub and kept it as a spare. Everything has been fine for over a year since I did that.
2008 JKU Sahara on jack stands with suspension completely removed, engine completely exposed, crossmembers cut out, and wiring harness dangling by the firewall. Soon, IFS front suspension with trailing arm 4 link in the rear.
GetLost is offline
post #7 of 8 Old 06-17-2019, 03:41 AM
Laggy's Avatar
Ever fix this?
Laggy is offline
post #8 of 8 Old 06-17-2019, 06:03 AM Thread Starter
Yeah. He says it fixed itself over a few days. It went away after about 4 days. Who knows.
Similar Threads
Wheel Speed Sensor Wire Extensions? mschaffer66 Electrical & Lighting Tech Dept. 12 08-25-2018 07:39 AM
Wheel speed sensor paramaniac Modified JK Tech Dept. 11 03-20-2011 11:36 AM
Wheel speed sensor wire snapped. AnkurGT Modified JK Tech Dept. 3 04-18-2010 05:31 PM
ABS/Wheel Speed Sensor - part number???? LSUjeepguy JK General Discussion 2 04-08-2010 03:09 PM
ABS Sensor/wheel speed sensor H8T2W8T Electrical & Lighting Tech Dept. 29 11-06-2009 03:35 PM
