Stripped ring gear bolt on carrier - JKowners.com : Jeep Wrangler JK Forum
 1Likes
post #1 of 30 Old 05-12-2019, 06:50 PM Thread Starter
So I was putting the ring gear on after installing my locker and tightening up all the bolts on a vise. This one had to be less than 50 ft Ib when it stripped. I have no clue what to do. Please help pls. The rest all got to 80 ft ib just fine. Helicoil maybe? I have no clue.
supercell is offline
post #2 of 30 Old 05-12-2019, 07:26 PM
So the thread in the gear itself stripped out? You'd probably need a new gear, I don't think I'd try to helicoil a gear but maybe someone more experienced in repair work will say it's fine.
What's the source of the bolt? Was it a brand new bolt included with the gear kit? If so I'd think they should send you new parts. Only way I can see this happening is if either the gear wasn't hardened properly, or the bolt was bad. Of course you'll have to convince the manufacturer that you didn't just break the parts due to operator error of installation, which may be easy or hard depending on the company.
christensent is offline
post #3 of 30 Old 05-12-2019, 08:20 PM Thread Starter
You know the bolts on the carrier holding the ring gear? One of those is stripped inside the ring gear carrier. It's the factory carrier and ring gear/bolts/everything. I just bought jbweld. Don't know what else I can do on the cheap. After reading lots of other threads, it looks like it's fairly rare for a bolt to cause lots of damage
post #4 of 30 Old 05-13-2019, 04:25 AM
BigTB's Avatar
The bolts thread into the gear, not the carrier. What threads did you strip in the carrier?
Are you sure it’s not the bolt that’s stripped, rather than the threads in the gear? Maybe you just need a new bolt. Any pictures?
BigTB is offline
post #5 of 30 Old 05-13-2019, 06:15 AM
it wouls take a very-well equipped shop to have a lath or cnc that was capable of trying to make any change to the metal used on a ring gear.
If you've stripped or misthreaded the hole and sheared one of the ring gear bolts you might could tack weld another to that for gaining leverage to extract but either way it sounds like you need one of two things, a new carrier or a new ring gear. The metal of the ring gear is almost too hard to do anything to, from my experience . Just widening the holes to accept larger bolts can take multiple cutter heads ....man would a picture link help in this instance !
edit: you mean the bolts pictured holding on this gear,right?
post #6 of 30 Old 05-13-2019, 11:57 AM
Pmedic920's Avatar
Iíve always heard that a helicoil is stronger than most original threads but Iím with others here, I doubt that you could successfully install one on the ring gear.
I easily could be very wrong though.
Pmedic920 is offline
post #7 of 30 Old 05-13-2019, 02:15 PM Thread Starter
Yea the threads in the ring gear my bad
post #8 of 30 Old 05-13-2019, 03:52 PM
Random Dude
Those should be pretty hard threads. Did they pull out straight out and come out intact on the bolt like a fake Helicoil?
Or was there a burr / smashed thread / cross threaded situation that caused the hole threads to be destroyed during assembly?
Not judging or talking shit, just trying to understand the specific failure mode.
Pics would help if possible.
ExWrench is online now
post #9 of 30 Old 05-13-2019, 04:12 PM Thread Starter
I already put it back in the housing. Looks shoddy af. I just jb welded around the bolt that was stripped. Doesnt let me upload a pic
post #10 of 30 Old 05-13-2019, 04:13 PM Thread Starter
I didn't even attempt to take the bolt out.
post #11 of 30 Old 05-13-2019, 05:41 PM
Random Dude
Without more information I can provide no productive feedback as to how best to repair the compromised threads.
If you're running that 1 bolt as (effectively) a dowel pin, consider chipping off the epoxy and putting a ~1/4" tack weld.
Between heat cycling, flexing, and a full-time bath of gear oil, I'd expect the JB weld to retire at some inopportune moment.
With a good tack weld, you won't have to fear the bolt backing out and causing an FOD-based failure of other parts.
Either way, I hope it holds together for you
post #12 of 30 Old 05-13-2019, 07:18 PM Thread Starter
Appreciate the info. I'm gonna have my axle welded up here soon, so I think i can open it up then and get it tack welded.
post #13 of 30 Old 05-14-2019, 02:07 AM
Laggy's Avatar
x2
The lack of a picture is stifling.
Did the bolt head snap off?
Or is the bolt thread spinning freely within the ring gear threads?
Looks like it doesn't matter because shit is all closed up.
I wouldn't weld shit to the ring gear. Blob of shitty weld that probably won't even penetrate the metal of that ring gear before a grade 8 bolt would fucking liquefy. Even a good tack. Then you have a marble of metal that might tear something up.
SMH
Laggy is offline
post #14 of 30 Old 05-14-2019, 09:21 AM
Random Dude
Originally Posted by Laggy View Post
x2
SMH
Yeah, let me clarify something: I'm not suggesting that a different hack fix is preferable to a legit fix.
Personally, I'd bite the bullet, pull it all apart, and repair or replace the damaged threads + bolt. R&R R&P, or at the least machine + install a thread repair insert (helicoil, timesert, keensert, . . . something capable of holding up to 120+% of nominal torque).
post #15 of 30 Old 05-14-2019, 10:30 AM Thread Starter
Pic upload fails every time I try. http://imgur.com/a/VoI3KVp the bolt is all the way in. Before the jbweld it spun freely at maybe a few foot pounds.
post #16 of 30 Old 05-14-2019, 10:34 AM
Random Dude
I think JKO requires 10 posts before you can upload a pic.
(not sure, but I believe they did that a year or 2 ago )
Put another reply in this thread, then try again.
post #17 of 30 Old 05-14-2019, 10:38 AM Thread Starter
The imgur link should work
Edit: still can't upload lel
post #18 of 30 Old 05-14-2019, 10:45 AM
Random Dude
Huh, I thought 10 was the magic number.
You should be good to go
Try posting it again, or type out the imgur link, and I'll link it for you.
post #19 of 30 Old 05-14-2019, 10:55 AM Thread Starter
h t t p : / / imgur . c o m/a/VoI3KVp
post #20 of 30 Old 05-14-2019, 11:04 AM
Random Dude
I went to the page you linked, opened the image, and put the image address below in IMG tags.
Do you have a pic of the threads disassembled?
That would help determine what's fooked and how.
post #21 of 30 Old 05-14-2019, 02:39 PM
That's the rear axle?
post #22 of 30 Old 05-14-2019, 04:36 PM
or, since hardened ringgears are not that accepting of heliocoils
and they can't be welded to real well for this situation , together with not being able to extract this particular ring gear bolt ... considering that these things aren't outrageously expensivee, I'd probably just replace it (unless we are trying to avoid doing it all over again or something) .
post #23 of 30 Old 05-14-2019, 04:41 PM
you're not doing it right. Why would the image attachment option - which is looking for a .jpg or .png or .tif file - accept that imgur image share link?
You need to understand how imgur works to know that you seek what's called a ' Direct Link' that will have a file suffix after it ...
The mobile app doesn't make the sharing links as varied as when you access the site thru a desktop web browser,if that helps ....
People make this so hard.
post #24 of 30 Old 05-15-2019, 02:04 PM
Laggy's Avatar
Honestly, Iíd go back in there and do a new ring gear. Clean up that jb weld off the carrier.
I donít get how on earth those threads stripped. Perhaps a machining defect? Machine tooling can go dull/bad and they didnít switch out until they made the ring gear after yours?!? Just a wild guess.
I assume all re-threading options were exhausted?
Laggy is offline
post #25 of 30 Old 05-15-2019, 03:42 PM Thread Starter
Sorry I made it so hard as I was doing it all on mobile. I drove 250 miles going 80mph and it held up great. Changing diff fluid again. I'm just gonna keep it as it is for now since money is tight and yea I don't wanna do this all over again. This whole process was a pain. It's on the front d30 and the bolts were 10 years old. Maybe if I got a master install kit it would have been fine. idk why else master install kits would include new bolts.
and j3ff3ry I never tried attaching an imgur link xd. I just uploaded to imgur and linked it after finding out attaching from my camera roll didn't work
Similar Threads
How to remove stripped Torx bolt? Sooner_Jeeper Modified JK Tech Dept. 3 12-29-2016 05:09 PM
stripped windshield frame bolt rubicon10a555 JK General Discussion 3 05-05-2015 07:15 PM
Stock rear driveshaft bolt stripped Scooter Scott Stock JK Tech Dept. 2 06-20-2012 06:45 AM
fixing a stripped trans pan bolt Ruskin Stock JK Tech Dept. 1 08-28-2010 09:06 PM
Body lift stripped bolt haddadk03 Modified JK Tech Dept. 12 11-01-2008 09:41 AM
