Poison Spyder Rear Flare Fit Issue - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 05-09-2019, 04:16 PM Thread Starter
SoK66's Avatar
A fellow club member asked me to help him install a new set of Poison Spyder aluminum flares. When we set the rears up into position we discovered a wide gap, maybe 3/8", at the arch at the front of the wheelhouse. Same on both sides. It's very doubtful this will close up much, if at all, when the flares are tightened down, and over torquing will spin the rivnuts. Anyone else with the PSC flares encounter this issue?
SoK66 is offline
post #2 of 9 Old 05-09-2019, 04:27 PM
blank123003's Avatar
the smitty bilts that came on my jk are similar i just assume its normal across the board
dont mind me im just a new guy here
blank123003 is offline
post #3 of 9 Old 05-09-2019, 06:35 PM Thread Starter
SoK66's Avatar
Well, he paid for a lot more than the Smittys. He contacted Poison Spyder and essentially got blown off. He bought them in bare aluminum and has paid for them to be powder coated, so he can't return. Sucks what he's got on his hands, I expected a lot more from Poison Spyder. My Nemesis flares fit perfectly.
SoK66 is offline
post #4 of 9 Old 05-09-2019, 06:52 PM
yeah, the Nemesis Industries wares will spoil you in the fitment.
It's tough to see if it is the same gap as is visible in this generic PS rear fender image versus yours, but there is an obvious gap,even in generic catalog images of the PS rear flares:
post #5 of 9 Old 05-10-2019, 07:28 AM Thread Starter
SoK66's Avatar
That’s not the gap he’s having issue with. The gap is between the flat surface of the body where the old flare attached and the mounting plate for the Poison Spyder flare. It’s flush from the rear around to the forward mounting surface, then there’s a big gap, then it’s flush at the bottom front. It’s like their template is bent, but both rears are roughly the same.
Last edited by SoK66; 05-10-2019 at 07:33 PM. Reason: Remove character added by iPhone
SoK66 is offline
post #6 of 9 Old 05-10-2019, 07:29 AM Thread Starter
SoK66's Avatar
BTW, sorry for the goofy "Â" character. The Forum adds that when I respond from my iPhone.
SoK66 is offline
post #7 of 9 Old 05-10-2019, 08:51 PM
Pmedic920's Avatar
I can’t contribute anything of value concerning the PS fenders, sorry.
I do feel compelled to say this however. I just installed some MetalCloak “hard line” aluminum fenders. “Fit” was almost perfect.
I had mine painted at a body shop to match my rig, the finish wasn’t perfect and could be touched up with a little more prep but I told the guy to just do a good paint job.
I’m happy with them.
Pmedic920 is offline
post #8 of 9 Old 05-11-2019, 06:31 AM Thread Starter
SoK66's Avatar
Yes, I did Nemesis Odyssey flares and would say the fit was perfect. There's nothing tricky about that rear fender seating surface, seems to me it was relatively flat all around. He contacted Poison Spyder again and they convinced him to try installing them. We'll have to see.
SoK66 is offline
post #9 of 9 Old 05-11-2019, 07:49 AM
funfred's Avatar
PSC fender...only issue is if I wanted to switch brands. I doubt the template for the mounting holes are the same between brands.
No idea why the pic loaded sideways.
funfred is offline
Similar Threads
Poison Spyder Brawler 2 Rear issue Justin JK General Discussion 3 02-10-2015 11:14 PM
Poison Spyder Brawler Lite - What Fog Lights Fit? JeepingGreen Modified JK Tech Dept. 2 03-12-2012 10:48 AM
Poison Spyder Full Cage Kits with Innovative "Lazer-Fit" Technology Dusty Vendor's Marketplace 154 07-07-2011 01:03 PM
Does a Rigid Industries Dually fit in a Poison Spyder front bumper? REBEL OFFROAD JK General Discussion 7 06-23-2011 12:41 PM
Left-Front Flare & Flare Support Needed TripleJackInGA Wanted 1 12-10-2009 10:31 PM
