BENT SWAY BAR: REPLACEMENT NEEDED - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By ExWrench
post #1 of 3 Old 05-08-2019, 05:39 PM Thread Starter
While on the rock portion of the 3rd level course at Jeep Blessing 2019 in Mesick, MI last weekend, I slipped off a rock and came down on my driver side sway bar connector. The result was an obliterated connector and a 30-40 degree torsion (clockwise from the left view) on the driver side of the sway bar. (pictures at this site => dropbox.com/sh/pu84z4t34gd8qe5/AACa0BQaXjJfiwt6gjdlA48sa?dl=0
Given that I have a 2008 JKU Rubicon with electronic sway bar disconnect, I’d like to keep that option rather than switch to a antirock system.
I am unable to locate a replacement sway bar WITHOUT THE ACTUATOR and most online part sites only show the whole mechanism sold together (>$1,500).
(see diagram => quadratec.com/parts/jeep-wrangler-jk-front-stabilizer-bar-parts ... #11)
Here are my questions:
1) Does anyone know where I can find just the bar that I can replace mine with (while using my current actuator)
2) Is it possible to remove the mechanism and try to “re-bend” the torsion back to a workable position? .. and if I do this will it compromise function and/or safety?
Any suggestions/tips/advice are greatly welcomed!
CITRON33 is offline
post #2 of 3 Old 05-10-2019, 11:56 AM
Looks to me like you just bent the sway bar link. Just buy a new link. Stock should be pretty cheap, or just get an adjustable aftermarket link.
That is assuming the sway bar itself isn't damaged, can't really tell in the pictures. Most likely the sway bar is fine and it's just the link.
christensent is offline
post #3 of 3 Old 05-10-2019, 12:43 PM
Random Dude
Yep, this^.
If you think your sway bar is ~30 degrees off, that's probably how the disconnect was indexed when you deactivated it. Actuate the electronic disconnect and it should all line back up.
Buy new end link, straighten out tab on axle housing, and reassemble (with disconnect actuated) - should be good to go for small cash and a bit of fiddling around.
rockystock likes this.
ExWrench is offline
Similar Threads
Teraflex Front Dual Rate JK Sway Bar and Teraflex ST Rear sway bar mikey_g For Sale - Jeep parts 1 11-28-2013 07:44 AM
Bent my Tie Rod... need suggestions for a replacement Nickit1981 Modified JK Tech Dept. 52 09-22-2011 01:28 PM
Replacement front sway bar options Goodysgotacuda Modified JK Tech Dept. 33 01-23-2011 10:22 AM
