Recommend a OBD/ABS/SRS Scan tool - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 04-24-2019, 08:20 AM Thread Starter
MAG00's Avatar
Can anyone recommend a specific OBD/ABS/SRS scanner? From searching online reviews the Innova 3100J and BlueDriver come up quite often. Other brands such as Autel and Ancel pop up too along with other models of the Innova brand.
Any specific brand/model you'd recommend? Want one that can read OBD, ABS, SRS. Any specific phone app/bluetooth adapter combo you would recommend?
'13 JKU Billet Silver, RockKrawler 3.5 lift, JRi Shocks, Currie VXR60s, Spyderlock Wheels, Nitto Trail Grapplers 37x12.50, ARB Twin with Lockers, PSC Hydro Assist, Superchips Flashpaq, Rubi Rails, Ace Rock Sliders, sPod, JCR Front & Rear bumpers, Engo 10KS Winch, KrawlOff-Road LEDs
MAG00 is offline
post #2 of 8 Old 04-24-2019, 08:34 AM
rockystock's Avatar
I have the Bluedriver. Works great. They update the app regularly for recalls/TSBs and probably other stuff. You can watch several data trends in real time on your phone w. Bluetooth. I'm planning/hoping to use the O2 sensor data to monitor air/fuel ratio and engine coolant temp. for a v8 swap. Don't have any experience with the other scanners.
rockystock is offline
post #3 of 8 Old 04-24-2019, 09:27 AM
I recently picked up a Foxwell NT630 Elite. It can scan and clear codes in the ABS/SRS system, and the reason I bought it is it can also run through the ABS bleed sequence. You can also use the NT650 that costs twice as much but has a bunch more features.
It's not a cell-phone based system but none the less is a really nice ABS/SRS scanner and tool.
christensent is offline
post #4 of 8 Old 04-25-2019, 05:54 AM
SoK66's Avatar
I found an OTC 3210 last year that will do all of the engine management, SRS and ABS codes. It will also run an ABS bleed routine for those who need it. It has been discontinued but you can still find them reasonable priced. The replacement will not do the ABS bleed.
SoK66 is offline
post #5 of 8 Old 04-28-2019, 08:31 AM
wrbrd@yahoo.com's Avatar
Elm 327 blue tooth scanners and the JScan app.
Sent from my iPad using Tapatalk
post #6 of 8 Old 04-30-2019, 06:10 PM
Banshee's Avatar
I have a cheap eBay ELM327 that I use with Torque, but a Bluedriver for getting codes etc as it is not limited to just the ECU as many are & will pick up codes from all the systems in the vehicle.
Originally Posted by Clone7
When you die, you see your life going by in a flash.
Steve Jobs didn't - Apple doesn't support Flash.
This message has been reviewed & approved by the NSA, Google and Microsoft.
Banshee is offline
post #7 of 8 Old 05-05-2019, 01:32 PM
reddog's Avatar
I have Blue Driver and it works the best over all on my LS converted JK. The best part is that they keep it updated.
reddog is offline
post #8 of 8 Old 05-08-2019, 05:41 AM
Check out the JScan app and a compatible blue tooth module.
Similar Threads
Affordable Scan Tool mrjosh The Tool Crib 7 02-09-2018 06:55 AM
Scan tool roll call moose4x4 JK General Discussion 7 01-10-2016 03:01 PM
Would like to borrow a scan tool jchurch USA - Colorado 3 09-08-2014 10:12 AM
$12.50 CLC 32 Pocket - Socket/Tool RollPouch and CLC tool bags SDMF Vendor's Marketplace 5 03-04-2011 12:11 PM
Tool Bags Tool Bags Tool Bags!!! TWISTED STITCH SEATS JK New Product News 25 04-15-2010 10:47 AM
