Slip Yoke Elimination???? - JKowners.com : Jeep Wrangler JK Forum
 3Likes
  • 1 Post By rockystock
  • 1 Post By Pmedic920
post #1 of 6 Old 04-22-2019, 08:48 AM Thread Starter
Pmedic920's Avatar
Please pardon my ignorance.
Id like to have a general discussion on the topic, for learning purposes.
What are reasons to do it?
Pros and cons?
Kits: good, bad, stay away from.
Have you done it, or considering it?
Drive shaft length, does it require a special length shaft vs an already purchased stock length?
Etc Etc.
Edit: its time to upgrade me rear DS, and Im wondering if I should consider SYE at the same time.
I know almost nothing on the topic, and only thought about it after looking at/for a rear DS.
Pmedic920 is offline
post #2 of 6 Old 04-22-2019, 09:29 AM
rockystock's Avatar
JKs don't have a slip yoke
KnightJK likes this.
rockystock is offline
post #3 of 6 Old 04-22-2019, 09:49 AM
bignblack's Avatar
SYE are great for closing off the t-case. TJ's were a better benefit to have.It put the slider on the shaft,in turn allowing for more travel. all your adjustment for travel is then on the shaft and not on the t-case output.I ran the crown kit with the shaft included.If you don't get a shaft you will need to have one made up or ordered for the SYE. The JK's shaft has a slip yoke built into the shaft. The downfall of the JK shaft is the joint at the t-case. Better off to change the shaft to a conventional style u-joints/double cardone.
bignblack is offline
post #4 of 6 Old 04-22-2019, 11:21 AM Thread Starter
Pmedic920's Avatar
Thank you both.
These responses do 3 things.
1)solve my dilemma
2)prove my ignorance
3) eliminate my slip yoke ignorance.
Im still pretty ignorant in multiple areas.
Thanks again.
mmilburn likes this.
post #5 of 6 Old 04-22-2019, 06:41 PM
rockystock's Avatar
Me too - didn't know the slider on the driveshaft is also called a slip yoke hmm.
post #6 of 6 Old 04-22-2019, 07:59 PM Thread Starter
Pmedic920's Avatar
Lol
But the statement did make me realize that my DSs have room to move.
Im not the sharpest knife in the drawer but it m not the one the wife used as a screwdriver either.
Cheers.
rockystock likes this.
Similar Threads
1" Body Lift Rear Bumper Gap Elimination BryGuy Write Up Dept. (The Library) 0 06-07-2010 07:51 PM
02 TJ Slip Yoke Recommendation? NxtGenCowboy Jeep CJ and YJ 2 11-23-2009 01:57 PM
1330 or 1350 pinion yoke ????? Modified JK Tech Dept. 10 04-23-2009 09:56 PM
replacing the rear output flange w/ a yoke xjninja Modified JK Tech Dept. 0 03-17-2008 09:42 PM
1350 Yoke for the JK Dana 44? ASTAR Modified JK Tech Dept. 6 12-27-2007 10:36 PM
