Swapping D30 to D44 Newbie needs help - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By rich6700
post #1 of 6 Old 04-15-2019, 11:44 AM Thread Starter
KAVIK's Avatar
Hi
I have just returned to the forum after a long time away.
so I'll sum this up as concisely as possible:
-I want to put a Rubicon Next Gen D44 in the front of my 2010 JKU Sahara, to replace my D30 currently there.(which is done)
-So I know I have to change the ring and pinion in the front diff of the "new to me" D44 so it will match my Sahara rear gears that are 3.73:1 This is correct?
-I'm no mechanic when it comes to this stuff, so please be patient (and hopefully kind lol).
-Are there any other things I need to know/buy etc...?
-I know I need transfer case oil, and the new gears, and some way to wire up the e lockers with a switch ,and fuse.
I'm on a budget (a low one) thus the D44 is coming from a wrecker, it was an unexpected (kinda) failure.
any tips , or pointers would also help.
2010 Sahara Unlimited. 33" Goodyear Duratracs, MOPAR Grab Handles front and Rugged ridge in back, SilverStar Platinum Head Lights, Gorilla Pod Video Camera Mount System,Kargo Master Kongo Cage,50" light bar, Rear tail light guards, gas cap cover locking, Smittybilt Jerry Can Holder, with Scepter military can, chopped stubby bumper... assorted decals . Other factory options.
KAVIK is offline
post #2 of 6 Old 04-15-2019, 01:54 PM
why not upgrade the rear gears to 4.10? Or just pull the front driveshaft until you can save up the money to swap the rear gears.
Why do you need transfer case oil? Don't you mean diff fluid?
post #3 of 6 Old 04-15-2019, 02:31 PM
Attenuator's Avatar
1. Not all Rubicon 44's have 4.10s...Some have 3.73's. Check this before considering replacement.
2. If it has 4.10s, swap the rear gears to 4.10...
3. Gear oil 75-90w
4. Wiring with a fuse should be cake, might be tough to find the correct plug.
Attenuator is offline
post #4 of 6 Old 04-15-2019, 04:39 PM Thread Starter
KAVIK's Avatar
Thanks Much appreciated. I did some extra homework on this after my post. Yeah a lot of Rubi's came with 3.73.....now to find one. Thanks for the note on the Oil.
I found a video on how to wire the lockers using audio jack plugs I may give that a try.
KAVIK is offline
post #5 of 6 Old 04-15-2019, 04:40 PM Thread Starter
KAVIK's Avatar
Yes diff fluid sorry...newbie..
good tips thanks Uncle Sam's
KAVIK is offline
post #6 of 6 Old 04-16-2019, 08:23 AM
rich6700's Avatar
Do not use audio jack plugs. Get a weather pack connector.
mmilburn likes this.
rich6700 is offline
Similar Threads
Is a D30 a D30 a D30? WRMorrison Modified JK Tech Dept. 6 08-03-2010 04:30 PM
4.10's for D30, D44, D44 carrier thaduke2003 For Sale 1 10-08-2009 07:39 AM
Newbie needs help with some options. Tank83 Modified JK Tech Dept. 17 04-28-2009 01:58 PM
Newbie needs help on off road lights pftcotter JK General Discussion 2 04-10-2009 08:14 PM
Longfield CVs for D44 with D30 Outers ---> Rubicon Front D44 Living Still JK New Product News 0 11-09-2008 06:20 PM
