14 Bolt Axle ABS Sensor Question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 04-06-2019, 02:37 PM Thread Starter
phillypete's Avatar
So I am about finished up with my axle swap. One of the last things I have to do it run the wires for the rear and sensors.
I have the Artec kit installed and sensors on hand, but I was just thinking would it be possible just to T-splice the front wires into the rear wires instead of running the extra sensors?
phillypete is offline
post #2 of 5 Old 04-08-2019, 07:50 AM
KnightJK's Avatar
What year is your JK?
Chase Weston
KnightJK is offline
post #3 of 5 Old 04-10-2019, 12:05 PM
elusive's Avatar
no. it needs 4 sensors.
elusive is offline
post #4 of 5 Old 04-11-2019, 08:00 AM Thread Starter
phillypete's Avatar
I have a 2013
post #5 of 5 Old 05-05-2019, 06:42 PM
As mentioned above, it needs 4 sensors. You can splice the front sensors so they all 4 run off the rear 14 bolt hub but you need an additional mount and sensor just like for the rear. You can't just splice into the rear 2 sensors to try and make it all work.
2010 Stone White JKUR
05+ Dana 60/ 01 14 bolt
5.38s/ Arbs
3 link/ coilovers
40" toyos
NJ-Rubicon is offline
Similar Threads
Dual ABS on 14 bolt Northernmedic Modified JK Tech Dept. 6 12-09-2015 01:58 PM
ABS sensor replacement question KevinJBurt USA - Colorado 4 08-26-2010 03:29 PM
ABS sensor machined into 14bolt (Pimpin Ain't Easy!) NY2PAJK Chit Chat 15 04-19-2010 06:43 PM
ABS Sensor/wheel speed sensor H8T2W8T Electrical & Lighting Tech Dept. 29 11-06-2009 03:35 PM
How do you replace the front ABS sensor? gt3073b JK General Discussion 14 04-24-2009 07:18 AM
