Parking Brake Alternatives - JKowners.com : Jeep Wrangler JK Forum
 5Likes
  • 4 Post By ALASHA
  • 1 Post By Fklein6768
post #1 of 5 Old 04-02-2019, 10:43 PM Thread Starter
My parking brake cables are really in the way of where I want to move my axle side lower control arm mounts. Anyone have a good alternative parking brake option for the JK? Plus even when freshly adjusted, the JK parking brake absolutely sucks in my opinion, most useless parking brake of any vehicle I've ever driven. Can't hardly keep my Jeep from bumping into the park pawl even on flat ground. More motivation to replace it with something better.
I'm aware of transfer case brakes, but nobody makes one for the JK transfer case and I don't want to buy an Atlas etc. just for that.
I'm aware of line locks, and would rather do something slightly safer.
Are there any products that I'm not aware of that bolt-on relocate the parking brake to something like a caliper or transfer case brake? Or any products that easily modify to work on the JK platform?
christensent is offline
post #2 of 5 Old 04-03-2019, 07:41 AM
ALASHA's Avatar
Sorry couldnt resist
ALASHA is offline
post #3 of 5 Old 04-03-2019, 09:29 AM
rockystock's Avatar
A set of replacement calipers with the e-brake feature would be pretty slick. Guess they're not sexy enough or the aftermarket would be all over them.
rockystock is online now
post #4 of 5 Old 04-03-2019, 11:21 AM
gt1guy's Avatar
Wilwood makes a couple different cable operated spot calipers. I don't remember how thick the JK rotors are, but the Wilwoods only work up to a .81" rotor.
https://wilwood.com/Calipers/Caliper...me=Mech%20Spot
https://wilwood.com/Calipers/Caliper...4%20Mechanical
I'm going with my own version of a line lock. Not the cheap electrical type or the Jamar mechanical one. I just bought a SS Swagelok 1/4", 1/4turn ball valve that's rated for 5000psi and has the right seals to work with brake fluid. It's a hundred dollar ball valve that will not leak down.
Kevin
gt1guy is offline
post #5 of 5 Old 04-03-2019, 03:31 PM
Fklein6768's Avatar
Those r fancy I just go with the HF special. Fits nicely under the seat and actually works
ALASHA likes this.
www.4x4s-pod.com
Fklein6768 is offline
Similar Threads
OEM front tow hook alternatives? IonicRipper JK General Discussion 6 01-14-2014 10:15 AM
Mopar Softtop hardward alternatives???? Jeep44 JK General Discussion 10 05-06-2013 11:42 AM
Viper TB alternatives j-rod17 Modified JK Tech Dept. 0 05-21-2012 11:34 AM
Alternatives to smittybilt Cargo Net SFBayArea JK General Discussion 10 05-01-2012 09:15 AM
Pinion alternatives ????? Modified JK Tech Dept. 3 11-28-2007 09:32 PM
