Lift question - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By rockystock
post #1 of 9 Old 03-28-2019, 09:08 AM Thread Starter
Lift question
Just wondering exactly where it is the drive shaft is put too far out of sorts with a 2door lift kit?
I have a teraflex 2.5 inch lift, then I added a smitybilt bumper and winch so I put in 2x 1" coil spacers in the front. I will measure the respective wheel well heights in a but, does anyone know the angle of the front DS or the front lift height that will be bad for the ds and pinion angle etc?
libordemise is offline
post #2 of 9 Old 03-28-2019, 09:51 AM
SilverBulletJKU's Avatar
You're definitely closing in on that critical angle, especially with a 2-door. Rear DS angles are way less forgiving than on a 4-door. Check for the front shaft contacting the exhaust at full droop and look at the rear for excess angle. I would be looking at new DC 1310 shafts front and rear pretty soon. Don't forget you need at least adjustable rear upper CAs if you decide to install a DC rear DS.
SilverBulletJKU is offline
post #3 of 9 Old 03-28-2019, 09:54 AM Thread Starter
Damn. I ASSumed the weight would put me pretty much level but I can see an obvious rake. Maybe I'll try it with the spacers removed. Pitas good to know about the DC rear requiring adjustable cas
post #4 of 9 Old 03-28-2019, 09:57 AM
you can go piss up a rope
snout's Avatar
I would mentally masturbate about caster before front pinion angle.
snout is offline
post #5 of 9 Old 03-28-2019, 10:00 AM Thread Starter
I have front drop brackets.
post #6 of 9 Old 03-29-2019, 12:12 PM Thread Starter
Ground is more or less level here.. does it look bad? I will have to find my tape measure
post #7 of 9 Old 03-30-2019, 08:05 PM Thread Starter
Does it look to severe?? I'm worried! Lol ds are not cheap. But I am.
post #8 of 9 Old 03-30-2019, 09:13 PM
rockystock's Avatar
Your front DS should be fine, but the biggest problem with it tends to be the rzeppa boot. It will probably develop a tear and start slinging grease on your tunnel and surrounding parts; but it will take a while. My boot gave it up after ~35,000 miles running on ~4.25" of lift up front.
libordemise likes this.
rockystock is offline
post #9 of 9 Old 03-30-2019, 11:04 PM Thread Starter
Oh... it's a CV at the tcase? Yeah that's a bad angle for those. My liberty had one and those boots tore incredibly easy
Similar Threads
Lift on lift question davjk09 Modified JK Tech Dept. 1 03-01-2011 11:10 AM
Lift kits, lift kits lift kits Paulie Vendor's Marketplace 5 01-27-2010 07:36 PM
Lift kit and sway bar question. dougnpj Modified JK Tech Dept. 2 05-05-2008 09:00 AM
Question for someone with poly performance lift? jeffmarion Modified JK Tech Dept. 2 03-24-2008 11:06 AM
Black Diaomond lift Question mdjprub Modified JK Tech Dept. 5 11-18-2007 08:06 AM
