straight bar drag link length - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 03-28-2019, 04:48 AM Thread Starter
hey everyone, I need some help. Im working on ordering all of my steering while im in AFG, so I can have it all when I get back, and get it installed. I found a place to get 7076 1.5 or 1.75 solid bar, cut to fit, and drilled/tapped for the ends. However, I am not anywhere near my Jeep to measure the length I need for both drag link, and tie rod. Can someone help me out, and measure their bar lengths? Also, does anyone on here currently, or know for sure if i can run 1.75" diameter tie rod without hitting dif cover at full lock? Thank you in advance
JonJK03 is offline
post #2 of 3 Old 03-28-2019, 07:56 AM
Call Synergy Mfg or Fusion4x4 and ask the length. Alternately , carry a tape-measure out w/ you to any mall nearby & just measure a draglink off any of the soccer mom JK/JKUs parked out front of the Old Navy or aerobics shop...
(edit: I wasn't joking about measuring another jks . However, you are leaving much data out so I did,too. A draglink that's flipped will require different lengths that one for OEM position. You still need to search internet but iirc the ext length of my synergy DL was 41-42" on 3" lift not flipped. Stock is likely between 38-39" min . )
post #3 of 3 Old 03-28-2019, 12:07 PM
Yes you can use 1.75 but it depends on the ends you use. Fusion 4x4 is 1.75 and uses Rare Parts ends.
2017 JKUR Recon 6spd Firecracker Red
SecTxAg06 is offline
Similar Threads
Passenger knuckle with insert for drag link flip, flipped drag link SGT. Jackalope For Sale - Jeep parts 4 07-20-2015 06:33 AM
Drag Link Length? Good Modified JK Tech Dept. 3 02-13-2015 11:30 AM
RK 3.5 Sway Bar link length JocKy JK General Discussion 9 01-14-2012 09:42 PM
one sway bar link not straight RUDY850 Modified JK Tech Dept. 9 06-26-2011 06:47 PM
front end track bar drag link help deekum1627 Modified JK Tech Dept. 27 06-03-2010 07:32 PM
