JKU homemade front winch bumper - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 2 Post By Dekooy
post #1 of 5 Old 03-25-2019, 06:27 PM Thread Starter
Hello again,
.......same story......I'm cheap but I like stuff, so I build my own. Today's thread is about my homemade front bumper. Some of you saw the half finished version at JK101 and here is the build...
This is my idea...
Off comes the bumper and I drilled 3 holes in the crossmember for angle brackets to the back of the winch plate for extra strength
I wanted no bolt heads on the front surface so I cut out bolt plates to weld 4 bolts to (each) as well as my 3/4 thick shackle mounts. The mounts are welded on both surfaces of the bolt plate, front and back.
I attach the front plate as well as the winch plate.
Dekooy is offline
post #2 of 5 Old 03-25-2019, 06:30 PM Thread Starter
Now I start adding the tops and the sides. There is also a view of the backside showing the winch plate and it's braces
Front lawn test of installed winch and this is how I wheeled it at JK.
Get home, rip it off, add the stinger and finish the sides....fun compound angles!
Dekooy is offline
post #3 of 5 Old 03-25-2019, 06:31 PM Thread Starter
Added a licence plate bracket and paint, just waiting for it to dry.
The entire thing cost approximately $120 in materials including paint. It took me about 35-40 hours of work, whenever I had the time/motivation. All work done with my PLasma cutter, stick welder, 4 1/2 angle grinder, chop saw, drill press and hand tools.
The paint is C-tire sourced "EZ-Liner" and at $10 a can I.m happy with how it went on and how good it bonds to the primer underneath.
Dekooy is offline
post #4 of 5 Old 03-25-2019, 06:33 PM Thread Starter
Here she is all done and on the jeep! I had an extra grab handle sitting around so I press-ganged it into duty as my cable holder!
Dekooy is offline
post #5 of 5 Old 03-26-2019, 07:30 AM
JKommuter's Avatar
Looks good to me. Its nice when people say "Nice bumper, where'd you get it?" and your answer is "I made it". Same comment as other thread, larger pics next time. Oh and welcome to JKO.
2009 JKU
JKommuter is offline
Similar Threads
JKU homemade rock rails Dekooy Modified JK Tech Dept. 3 03-25-2019 06:17 PM
JKU homemade HiLift mount Dekooy Modified JK Tech Dept. 1 03-25-2019 06:10 PM
Homemade Stubby Front Bumper mishtevan Write Up Dept. (The Library) 4 03-07-2014 06:43 AM
Homemade winch plate for stock bumper 4x4x4 Modified JK Tech Dept. 12 02-07-2010 05:19 PM
Homemade "stubby" front bumper? rdhrd4 Modified JK Tech Dept. 10 12-22-2009 07:01 AM
