Prorock 44 Install - Passenger front axle won't go in - JKowners.com : Jeep Wrangler JK Forum
 3Likes
  • 2 Post By Texas_Jester
  • 1 Post By Texas_Jester
post #1 of 12 Old 03-24-2019, 01:57 PM Thread Starter
Texas_Jester's Avatar
HI guys, hoping for some help or direction here, I am installing new axles in my 2017 jku, I just put a Prorock 60 in the rear and a Prorock 44 in the front, all is good and i'm down to sliding the last passenger side (long) axle back in the front and it will not go, seems to me it has to be an alignment issue on my part, but I've tried everything I can think of now and been messing with it for over 4 hours total the past two days. I've had it out and back in so many times in the last 4 hours that I would have thought it would have lined up by accident at some point.
There does not seem to be any kind of alignment aid or anything in there in my way like a factory axle would have, I have tried using the factory alignment shims to no avail, it goes through the seal and actually seems to engage the carrier gear as it will turn the opposite axle as I turn the one that won't go in, it hangs up every time about 1/2" from where it needs to be.
The axles came installed in a fully assembled dynatrac pro rock 44 with arb locker and its definitely the right axle and right length. I swapped out my factory spindles to put on the 44 so I had to pull the axles to do so. I am beyond stumped at this point. Any tips or pointers would be appreciated as I am dead in the water at this point trying to get it back together.
Thanks in advance for any insight
Texas_Jester is offline
post #2 of 12 Old 03-24-2019, 04:32 PM
what's it look like inside the carrier or feel like? Have you opened the diff to see? It takes often a lot more pre-lube on those splines for new, tight tolerance shafts to get into the groove sometimes , so don't hold back on the assembly lube or redNtacky for this.
you have tried tapping them w/ BFH once you have them spinning opposite side? It is also possible you got a seal sideways or off center and maybe preventing further insert?
post #3 of 12 Old 03-24-2019, 08:33 PM Thread Starter
I pulled the diff cover to see what I could tell. Not much to see with that locker in there, have not used the BFH as I was more worried I might damage something. I’ll pick up some lube and try the hammer as seal looks straight to me best I can tell. Driver side (short shaft) slipped right in with no resistance at all, really has me stumped.
post #4 of 12 Old 03-24-2019, 09:23 PM
Keep us posted. I also have a Prorock 44/60 on order
Punkn is offline
post #5 of 12 Old 03-25-2019, 08:17 AM Thread Starter
Will do @Punkn
@j3ff3ry_j33p I am starting to think that maybe the axle is going in all the way. When looking through the axle tube I can see where the end of the axle has been against the center pin in the carrier and has marked it (assuming from my 60+ times of sliding it in and out and tapping on it to ensure it is seated).
When pushed in as far as I can get it to go, there is a 5/8" to 3/4" gap between the axle tube and the back of the axle shaft (on passenger side there is only like a 3/8" gap) so I have been assuming that is too much gap, but if I were running axle seals that would actually leave very little clearance.
However, when I install and tighten the unit bearing on that passenger side, everything seems to get into a bind and its difficult to turn that knuckle. Could this just be due to the new ball bearings, etc.??
Am going to try and re-measure and reset everything again at lunch time today and see how that turns out.
post #6 of 12 Old 03-25-2019, 08:58 AM
eloucha's Avatar
Now I am thinking twice I talk to dynatrac the other day I was abt to order one I have to hold my horses now and see what will happen with u. By the way seems dynatrac have very good customer service did u contact them they will help u. Give them a buz and keep us posted plz.
eloucha is offline
post #7 of 12 Old 03-25-2019, 09:11 AM Thread Starter
They do have good customer service, all this happened over the weekend so I did not try to call them, and I am waiting for them to open this morning, I really don't think its an issue with Dynatrac or what they have provided me, I will continue to update this post as I move along.
UPDATE: I just got off the phone with Dynatrac, very helpful and good conversation, I will be taking some pictures for them to run it by one of their techs on my lunch break today, I will update this when I have more info.
post #8 of 12 Old 03-25-2019, 11:18 AM
Dkjeep's Avatar
I had an axle shaft once that was an 1/8" too long and was close enough I didn't notice until I had already ran down the 3 screws for the unit bearing and it wound up trashing the bearing. I sent it back but could have just ground some off the end.
I would take a stick or something and run it to the carrier pin and measure it. Then compare it to how far the axle shaft is going in.
Dkjeep is offline
post #9 of 12 Old 03-25-2019, 12:17 PM Thread Starter
thanks @Dkjeep ........just got back from doing some measuring and checking and talking with Dynatrac as well as sending them some photos. This appears to be the exact problem after measuring the axle and running a tape measure in until it bottoms out. The axle is actually bottoming out against the carrier (locker) center pin and then the unit bearing is bottoming out against the axle about 1/4" from where it needs to seat up. Trying to sort whether axle is too long or tube is too short, but either way this is where the issue is.
If I have 5/16 of an inch milled off the shaft then its going to put the seal very close to the end of the seal seat, so waiting to hear back from Dynatrac after they do some internal investigating to see what the path forward is going to be.
@j3ff3ry_j33p your trick with the red n tacky is what actually led me to see what was going on as it left enough of a lube line on the seal seat and the splines for me to see exactly where everything was, then when I got the tape measure out it was apparent that the axle was not hanging/binding, but was actually bottoming out and just too long.
I'll keep you guys posted as to the final outcome.
ndtguy and eloucha like this.
post #10 of 12 Old 03-27-2019, 12:25 PM Thread Starter
With Dynatrac's review and input (and warranty support) we are milling the end of the axle shaft down so it will fit and moving on. IMHO they did a good and thorough job with customer service. Just wanted to close the gap for the few of you that seemed interested.
post #11 of 12 Old 03-27-2019, 01:25 PM
good news, but how the hell did they get it in?
post #12 of 12 Old 03-29-2019, 01:56 PM Thread Starter
What they sent me was a fully built front axle, less the knuckles, I am re-using the knuckles from my current axle housing, so they just had the axles slid in the housing and zip tied to the C's to keep them from sliding out - nothing there to confirm how deep it was seated or how far it was sticking out and when just looking at it, 1/4" isn't easily visible until you try to seat that unit bearing
Similar Threads
WTB 44 ProRock,Teraflex, currie front axle MAXHHANN Wanted 6 08-13-2018 09:12 AM
Prorock 44 and prorock 60 rear Kriegjk For Sale - Jeep parts 10 12-27-2015 11:10 AM
ProRock 44 / ProRock 60 SF 13_gecko_rubi For Sale - Jeep parts 7 12-23-2015 04:41 AM
Built Prorock 44 and rear 44! Black Lady For Sale - Jeep parts 9 07-05-2012 08:30 PM
Prorock 44 axle shaft install question OlegRock Modified JK Tech Dept. 2 10-04-2011 01:11 PM
