Elocker disturb pinion? - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 1 Post By hokiewest
  • 1 Post By rich6700
post #1 of 4 Old 02-23-2019, 10:49 AM Thread Starter
Looking at regear and noticed something about the Eaton e locker for the rear d44
It looks similar to the Detroit truetrac...
Can I slap a ring gear on it, run the wire through the diff housing, reshim and if the backlash and contact pattern are good, run it?!
Does the pinion need to be mucked with?
libordemise is offline
post #2 of 4 Old 02-23-2019, 05:02 PM
hokiewest's Avatar
Are you changing gears and lockers? If just swapping carriers/lockers from one brand to the other then you can reuse the ring and pinion gears as long as they fall under the new lockerís gear range (D44 carrier break point is at 3.73 and 3.92). However if you are changing the ring gearís numerical value then yes you would have to swap for a matching pinion.
libordemise likes this.
hokiewest is offline
post #3 of 4 Old 02-23-2019, 08:14 PM Thread Starter
Im getting a guy with a bench to do the gears and I will take out the carrier and replace with either an Eaton or a truetrac.
post #4 of 4 Old 02-23-2019, 08:27 PM
rich6700's Avatar
If your just swapping out the carrier just put the old ring gear on the new carrier. Check the back lash and pinion depth. 9 times out of 10 it's a simple swap.
rich6700 is offline
Similar Threads
Eaton 4 pinion Elocker Failure 68w30 Modified JK Tech Dept. 20 11-20-2014 06:51 PM
Does anyone have a 4.10 ring & pinion for a low pinion TJ front? Ron R Wanted 0 11-20-2010 03:54 PM
Pinion Bearings? Pinion Seal Only? tkob1060 Modified JK Tech Dept. 10 04-14-2010 08:07 PM
Follow up to rear pinion seal leak and play in pinion. planman Modified JK Tech Dept. 23 01-19-2010 06:23 PM
Rear ELocker Not Working squirrel80 Modified JK Tech Dept. 13 01-03-2009 07:10 PM
