1 ton tone ring problem - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 02-21-2019, 06:48 PM Thread Starter
Quick question, I am 99% done with my 1 ton swap. 2005 f350 d60 front and 10.5 sterling rear. my front speed sensors work great with the dodge sensors. I have the artec rear speed sensor mounts all done up and mounting flush with brand new sensors. I also have 52 tooth ring pressed on the rear hubs. my passenger rear speed with jump around from 4mph to 50mph to 39 mph to 2mph. when im only doing a steady 10mph. my rear drivers side wont read at all. would you have any recommendations? I have been stuck like this for some time and would like it fixed. im open to any ideas. thanks for your time.
jkugeza is offline
post #2 of 3 Old 02-21-2019, 09:46 PM
Mason's Avatar
Have you tried putting a new sensor in either spot? Is the harness in good shape? Is the plug broken?
Mason is offline
post #3 of 3 Old 02-22-2019, 03:10 AM Thread Starter
I have tried 4 brand new sensors, the harness worked just fine when I took out the 44 axles, I thought maybe it was the plug, so I bought new plugs and spliced them in.
jkugeza is offline
Similar Threads
Tone Rings and Sensor Bracket Kits For JK 1 Ton Swaps Artec Vendor's Marketplace 0 05-05-2015 01:15 PM
Tone ring question rugger99 Modified JK Tech Dept. 2 12-30-2012 07:24 AM
Ring Tone Psycho T Chit Chat 13 04-10-2011 09:28 AM
D60 Full Floater Rear ABS Ring Tone JK07 Modified JK Tech Dept. 3 12-21-2010 09:16 PM
ABS Tone Ring Part #? PhilD JK General Discussion 46 06-01-2009 10:01 AM
