Recommended 3" lift? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 02-13-2019, 06:42 PM Thread Starter
illesg3's Avatar
Must be lots of folks with different lift kits.
What d'you recommend for (about) 3"?
Forget anything that needs different control arms. Also, I'm weight-sensitive.
thx
G.
illesg3 is offline
post #2 of 7 Old 02-13-2019, 06:46 PM Thread Starter
illesg3's Avatar
Should've mentioned: 2013 JK Sahara.
illesg3 is offline
post #3 of 7 Old 02-13-2019, 07:04 PM
you can go piss up a rope
snout's Avatar
Welcome to JKO. I refuse to answer your question.
snout is offline
post #4 of 7 Old 02-13-2019, 10:43 PM
I have a feeling there are at least 3 to 5 or maybe even 6 other threads where 1 or 2 different options are covered.
libordemise is offline
post #5 of 7 Old 02-19-2019, 07:41 PM Thread Starter
illesg3's Avatar
Hmmmm. Thanks, I guess. I did try a search or three before I posted, and I kept getting hundreds of hits with little or no relevance.
'13 JK -- "Roamyo"
illesg3 is offline
post #6 of 7 Old 02-19-2019, 07:47 PM
In my opinion at 3" you'll want at least 2 arms at each end. All 4 are better, but at least 2 adjustable arms (uppers or lowers) will help you dial in the pinion angle. Rock Krawler, MetalKloak, Teraflex would all be fine. Off Road Evolution have some nice kits as well.
18 JKU Granite Crystal- 4"lift, 40s, UD60s
07 Red Rock Crystal JKU - Sold
RedRock0740 is offline
post #7 of 7 Old 02-20-2019, 09:06 AM
Try going to the "modified tech" section of the forum, read the stickies (top threads) and scroll thru the threads. You will find a bunch of threads on lift recommendations and you may be able to ask a better question then you did here.
Similar Threads
Recommended New Lift Cool Hand Luke Modified JK Tech Dept. 1 01-31-2013 11:40 AM
4" lift, recommended tires? brill301 Modified JK Tech Dept. 8 10-12-2011 02:59 AM
2dr rubi with 37s and 4" lift recommended next mods rockygap Modified JK Tech Dept. 8 08-01-2011 05:42 AM
What are the recommended trail tools and spares...? SKeene JK General Discussion 12 04-06-2009 08:36 PM
Recommended 2.5" to 3.5" lift for these specs? titanus Modified JK Tech Dept. 12 03-13-2009 08:48 PM
